Hi Guys,
I did a search for Transmission oil in this forum and I couldnt find anything to confirm for a 2003 V35 Coupe AT, is it the same transmission oil as the 350Z? J-Matic?
I'm approaching 70k's, and my mechanic told me the oil should get changed when it starts to go very dark, which mine is..
Has anyone ever done a change on an AT? how much oil do you need and how much did it cost?
Cheers.
https://www.sau.com.au/forums/topic/317660-at-transmission-oil-for-v35-coupe/
Had my trans oil changed by nissan when I hit 65k mind you they only used one bottel so im guessing they only drained the pan, a full flush should use 2 bottles and yeah only use Nissan J matic
  • 3 months later...
Nissan quote me $260 to change my 6mt transmission oil. For a full flush it's $460. I was thinking if I should just buy the oil from Nissan and take it somewhere else to do it if that's cheaper. Can workshops do a full flush?
Hi Guys,
Cheers.
Yep, Matic J or Nulon 100% synthetic transmission fluid (I have used this for the past 60,000kms - no worries)
Matic D or Dextron III will destroy your clutch packs faster than you can accelerate to 100kms.
Take it to another Nissan Dealership.
Nissan Ferntree Gully in Vic do a full flush on their machine with Matic J (this includes the transfer case for my car - AWD) for $275. You should also ask for their additive pack to be used in the flush (all new Nissan have this added prior to sale).
Thanks for the tip I will give them a ring!
I wouldnt be putting Nissan J-matic into a 6MT transmission :D
haha, indeed!
I was merely quoting what they charged me for the Matic-J flush + additive satchel.
One would think that a manual box flush would be about the same price or possibly less due to the gear oil required.
  • 11 months later...
  • 7 years later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
