hey as the title says i just want to know how hard it is to remove the rails, is the bolts on the rail it self or do i have to remove the roof lining and do it that way cos i have found a place that will fabricate the rails for 50 bucks each and now i just want to know if its gonna cost me more then i have planned.
Thanks
josh
https://www.sau.com.au/forums/topic/317774-roof-rail-removal/
If you're looking at removing the roof rails, and making the roof smooth, then wait for a couple of weeks: we have contracted a body shop to mould a kit for us, and the first batch is due to be delivered in the next week or 2.
Basically, I bought a set of rail replacement panels from Japan, but was not happy with the fit, so the shop we are dealing with have chopped them, moulded parts from the original rails etc... They have their own Stagea to test on, so we are expecting a very impressive result.
The workshop making them is based in Sydney, so it won't soct too much in freight.
Stand by for pics of the fitted product as soon as I get them...
  • 11 months later...
sorry to bring up a old post but did you ever end up making the roof rails?? preety interested
As I recall this was a bit of a debacle; went on for ever...
http://www.skylinesaustralia.com/forums/topic/305804-roof-rail-replacement-kits/page__p__5205671__hl__roof+rails__fromsearch__1#entry5205671
i'm amazed that it can be so hard.
i feel for the people involved who obviously got mucjed around by a supplier who over-promised and under-deliverd, but really - they're two long flat bits with a slight curve at the end. a metal fabricator should be able to knock some out in a day.
We ended getting 4 sets made. Only took 13 months, we were promised 6-8 weeks.
$600 a set and they dont fit. I have 2 pairs standingg up in the corner of the garage.
I think they need a good days work to get them flat and sitting right before painting.
I have not had time to do it, maybe soon
Not that easy welding up the factory ones. they are very thin s/steel with a plastic/rubber coating. that would have to be removed to weld them which would stuff them up as the last 50mm each end is plastic not metal.
Hmmmm. Il have to see if anyone has a spare set and have a look at the options. I think a tig might get away with it but as you said the plastic coating will probably have to be removed first. But mine is already peeling and I need to take the rails out to re paint my roof anyway.
Can someone post up a pic of the roof with the rails removed? I am planning to remove mine at some point and would like to see the nature of the problem - I am imagining four holes of some sort in the roof and was planning to just weld steel into the spaces but people are suggesting it is somehow more complicated??!
  • 4 months later...
ive got an idea on the go. if it works out i'll share.
well my idea worked out, but its a huge job! something only a highly experienced professional should attempt! i wouldnt recommend it unless ur doing a complete teardown and respray.
hopefully it will look good once the paints done.
  • 1 year later...
Finally got around to painting and fitting mine yesterday........only took me 2 1/2 years to sort it
Its now ready for new owner of my car.....hopefully it gets picked up tomorrow...no more Stagea for me...
Edited by darrinspencer
I hope u dont stay away forever darrin. I know those ideas r in the back of ur mind ;)
  • 4 years later...
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
