Hey, i got to watch my car on the dyno the other day and noticed it had heaps of air/white smoke coming out the cam covers breather hole as i had the catch can setup disconnected, it started at 3000 as it started to make boost and by 7000 it was a pretty substantial plume of smoke/air, alot more smoke than i would of expected for blow by..
The engine has done roughly 1300kms, used 9:1 cp pistons and rings, i compression tested it the other day when it was cold, since the car is missing a radiator atm and got roughly 158-160 for pistons 3-6 and 155 for 1 and 2, wont be able to compression test it warm until i get my new radiator.. should i get a leak down test done as well or is this usual for a forged engine and im just being a bit paranoid?
Cheers
Jarrod
https://www.sau.com.au/forums/topic/317913-concerned-with-new-engine-on-dyno/
i built it myself, first time i have attempted anything like this, made harder by the choice to ceramic coat everything
Elite Racing:
Cheers for the advice, i just wasnt expecting it to breathe so much.. almost looked like more air was coming out the breather than the exhaust
Jarrod
Elite Racing:
Jarrod
Yeah a lot of people freak out when they see it. It's gas fumes created by the approx 10%-15% of leakdown that every engine has. Imagine the cylinder pressure once you throw in 15 to 20 psi of boost. On a 100psi regulated leakdown test you would see a value of approx 15 psi escaping. When you are cramming boost in and combustion pressure also, that increases to around 300psi cylinder pressure or there abouts possibly more. So you can have around 40-60 psi of pressure bypass the rings but not constantly. It's just little amounts as the combustion and stroke is so fast.
Add 6 cylinders all doing the same thing and it's almost like a mini steam train if you leave the breathers off.
With compression of 160psi on all 6, it sounds like you did a decent job of the build.
It's when it starts blowing raw oil out that you need to be concerned.
My did the same thing, even blew a bit of oil out of the catch can, that was even after running the engine in after 5000k's. Found that after the motor ran had done approx 7k, the breathing stopped. On the other hand, a mates 32 GTR does the same thing and has done more k's then I have and he's using CP pistons and rings like you. I had read somewhere that the CP rings had dramas with sealing properly and scoring the bore, but I think they fixed that problem. See how it goes with a few more k's on the engine, it might settle down.
Elite Racing:
thanks alot for that elite, thats a real load of my mind, my main concern was that i had done something wrong or it was something out of the ordinary, a mini steam engine is definitely the right description for it.
116.hks:
Yeh i had heard that as well and that they had fixed it as i was considering sticking in ACL rings, hopefully it seals up a bit better as it clocks up more kms.
Cran:
haha jason, ill make it there oneday, just got to figure out why the torque was dropping off earlier now.. which i think is due to the cams maybe being advanced, hopefully the radiator arrives next week sometime and the car will have the new exhaust made up.. and ill be able to take you for a spin
Jarrod
Status: id say it was steam.. more so than smoke.. i just remember thinking it looks alot like a kettle.. my piston to bore clearance was 3.5 thou from the pistons size before they were ceramic coated, the ceramic shop said because the pistons were getting ceramic coated they wouldn't expand as much. So the dry film lubrication layers thickness wouldn't effect the piston to bore clearance.. hard to say exactly what the clearances were without buying a micrometer and checking them myself, which i was considering, the bore was bored out 1 thou extra than the specs since the machine shop measured them and claimed the pistons were all 1 thou bigger, which i had double checked by a engineering shop.. i did roughly check the clearances with a feeler gage, but considering the bore and pistons are both round n they feeler gages dont like to bend it isnt very accurate, off memory (which isnt very good) i managed to get the 1.5 thou size in, but the 2 thou clearance was extremely tight..
Jarrod
when i was looking at r32 gtrs begining of the year, i had this white one idling, i opened the oil filler cap on the engine, it was "choofing" masses of white misty air, it was pretty high pressured too the smoke was almost going up to the bonnet !
what does this exactly mean? i always thought it was blow by/ alot of blow by, so im assuming worn rings? low compression ?
What does it smell like? If the rings aren't sealing correctly it will have that combustion/oily smell. Makes ya feel a bit sick in the gut after a while. From what I've seen and heard, it only has happen to motors running CP piston and ring combo. Just keep an eye on it mate, if it does stop with more k's, get it checked.
i didn't end up sticking in a oil restrictor as i did the internal vct oil feed where it gets its oil feed from the oil gallery, i assumed once the vct turns off after 4k that the oil would also be draining from the vct oil return line, i did install the rear oil drain kit and drilled the oil returns out larger in the head, which seems to be adequate enough
Cheers for all the input guys, ill monitor if it changes over the next few 1000kms and see if its losing any oil
Jarrod
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
