Okay guys, just a theoretical topic for some discussion.
My 34 GTT is currently in the shop getting a Haltech P2000, GT3076, 800cc injectors, clutch, fuel pump and all the rest - hoping for a 250rwkw daily 15psi and 300(ish)rwkw 20psi tune.
Now, my thoughts are turning to 0-100 km/h times.
Obviously this question is a bit like "how long is a piece of string" - depending on driver, tyres, road conditions etc etc but i thought it might prove interesting to hear other's thoughts (and if possible timed 0-100 times) from those that have or have driven 250-300 rwkw skylines.
The new XR6Ts apparently do 5.1 seconds all day long without the need to really stall it, while 34 GTRs (stock) can do 4.9 if banged off the rev limiter and dumped so I guess i'm interested in a comparison (not that i would give my 34 up for an XR6T - well at least not until the family requirements change and the 34 ends up as a track car!).
What does everyone think (or know...)?
https://www.sau.com.au/forums/topic/317960-modified-skyline-0-100-times/
  • Replies 191
Posted Images
If you can get a 250-300rwkw GTST/GTT to hold traction well off the line (good street tyres/semi slicks) a mid 4 second time should be fairly easy. Traction of the line is the hardest thing though, mine lights up 255 Toyos with ease at 3500rpm in first which becomes a problem. Would love to get it to hold first though, would be fantastic off the line.
Edited by PM-R33
And just a light launch, say just enough so you don't bog down - an easy 5s flat wouldn't be out of the question I assume?
I'd think that with that much power the pull towards the top of 1st and into 2nd should move it fairly quickly even without a great launch?
And speaking of tyres, does running a lower pressure on street tyres / rims (say 18s or 19s) make any difference to traction...?
Edited by gwilkinson34
it's all in the launch and car setup / suspension if you want low 0 too 100km/h
the one i did 4.88 was prefect launch with brand new pzero 255's and 190rwkw
the car had some basic suspension work, pineapple kit, camber, castor and bushes from memory
you need to get off the line with no wheelspin and grab 2nd as quick as you can when you top 1st
dont bother for 3rd, youll pass 100km/h before you top 2nd gear
for tyre pressure if you want off the line run 18-20psi in the rears and your acceleration will be quicker with smaller wheels, ie 17s instead of 19s
I was thinking of sticking some pzero 265/19/30s on but at $900 each that's getting a bit pricey... :D
Guess i'll see how bad it is when i get it back at the end of next week and decide how much $$$ i need to spend to get traction...!
Once my Toyo's are a bit worn im going to try some KU36's and with some lower tyre pressure im hoping they will hold allright.
i think there would be a sweet spot for the fatest possible acceleration in 0 to 100km
after that, any more power at the rear just results in wheelspin / slower times
i think the std turbo and basic mods to 200rwkw is when the GTST is the quickest in 0 to 100
i think with sub 280rwkw it may be a touch slower with wheelspin
after 100km the 280rwkw+ would walk away
but 200rwkw with traction would nail it i reckon vs 280rwkw and wheelspin
Yeah I find that to be the case. With a complete stand still I struggle to get it off the line quickly just because it breaks out like a bitch. Anything from a slow roll on and it's great.
The key definetely is in trying to get the suspension and tyre setup in a sweet spot to get the power down as early as possible. Any slight wheel spin will kill the 0-100.
Edited by PM-R33
I guess you could always try not putting your foot to the floor in the 250kw+ Skyline and feeding it in..? Guess that can be a hard ask in the heat of the moment. Will have to see how i go next weekend i suppose...!
I don't want to get beaten by a fairly standard skyline (or a bloody WRX) after spending the amount I just have for 250-300kw so i might just get some damn good tyres...! :D
I guess your usual inner-city drag doesn't start off with a full on launch though anyway, it's usually the feel each other out through the first half of first, then once you both know you are going to go put the power down... Am I right to assume that in that situation the 250-300kw Skyline is going to leave the 200kw one, or the SS / XR8 / WRX in the dust (obviously that is then taking the launch out of it...)?
wheelspin is a bitch...ive got around 200rwkw i raced my mates s2000 he smoked me at the start since the hondas are light as a fether and my wheelspin was going like crazy.. raced a wrx when i dumped it on second wheelspin set me back.. yea sounds like im still a beginer in shifting.. :blush:
I don't want to get beaten by a fairly standard skyline (or a bloody WRX) after spending the amount I just have for 250-300kw so i might just get some damn good tyres...! :blush:
Lol,
When i have a go at someone at the lights, you usually know well before hand that it's on, so i just bring revs up to 7k and dump LOL.
Cheers,
Mitch.
I have recently tested mine with my ecutalk thingy and not sure how accurate it is.
With around 225rwkw i manages 5.5sec. Just had it tuned to e85 (250rwkw) and best time 5.75. Add another full second if i bog down a bit. My 5.5 run had fair bit of wheel spin in first. I could probably ride the clutch a bit to bring the times down but cant be stuffed. Tyres are 265 (cant remember brand) but at 30psi.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
