stripping the 32 as ive purchased a 4 door-
gtr front bar with lip
fibreglass copy
lil bit of damage
easy repair
$150
r32 gtst stock rims
16" with rwc tread
$200 for all 4
3" front pipe(dump to cat)
good cond
$100
turbonetics 35mm external gate
$150
blown hypergear tr43 turbo
needs bearings
35mm tial copy gate welded to exhaust housing
v band dump welded to turbo
$200
rb20 r32 engine loom
$150
rb20 manual ecu
$100
stock r32gtst fuel pump in cradle
$50
rb20 auto gearbox
mint
$200
auto tailshaft
$80
r32 gtst 5 stud brake setup with hubs etc
calipers,rotors,pads,hubs etc
$500
r32 brake master cylinder and booster
$100
2X r200 lsd's
both mint one has 70k other 110k
$100 each
rb20 green label afm
$80
r32 gtst passenger seat
mint
could do with a clean
$80
r32 tail lights
$100 the pair
r32 headlights
projector style
$80 each
right hand orange indicator
$40
r32 blueface instrument cluster
130kms
$50
gktech steering wheel with boss kit
$100
r32 front subframe
$50
r32 rear subframe
$50
r32 front lca's
$100 pair
r32 stock front swaybar
$50
1992 r32 gtst bare shell with all glass,dash pad etc
green
all panels
pedal boxes
fuel tank
jap tint
reg'd in VIC
no defects ever
$500
car has til friday to sell whole then mass strippage will be happenin
0431683303
northern suburbs adelaide
Hey mate i just need the rear 5stud hubs and brake setup.
Are you willing to separate and how much for?
Also interested in the engine loom if its for an rb20det.
Pm me.
Cheers.
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
