  • Replies 57
yes good call and when selling a car try to take it to there house :) even insist if they want to test drive your car go pick them up might cost you some fuel but at least you know where they live, most people don't shit in there own nest
Only found out yesterday that Conrads 350Z with the APS twin turbo kit was stolen to and found burnt out near mcClaren vale :(
holy crap. i go offline for a while and come back to learn that two cars that i love are gone :-(
Conrad's zed was a beautiful car and Bengi's 31 was so cool to see out on the track.
wouldnt ya just love to get your hands on the dickheads that burn cars out? strap em down and get the mig welder out
-D
Just back over them. Less "premeditated". Then you can tell the cops they tried to hijack you ... you bailed and they got in the way.
:thumbsup:
:thumbsup:
or just stand in front of Shane's 350Z while Christine hops out for a sec to check her letterbox........oopsies, sorry Shane :P
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
