Hi all,
Recently I was given a nice little yellow sticker by our friendly law enforcement officials, and was told upon going over the pits that I must obtain permits for all the performance based mods on my car (intake plenum, injectors, afpr, high mount kkr480 etc. There is a five week backlog to even obtain permission to get an engineer to sign off on it all, so I have decided its not worth the heartache and I will be returning it to (nearly) stock.
I have just ordered a HKS GT-RS kit(going to be painted black and invisible), and I'll be putting the standard intake/exhaust manifolds, fuel rail etc etc back on
A couple of questions though:
1. Will the standard exhaust bolt up to the HKS dump? (My 3" is ever so slightly too low, by about 2mm at the cat so I will swap it over again after)
2. Boost contollers- I am guessing that these are illegal as well?
3. Intercooler - It is a genuine greddy so no issues with cut bumpers etc but are these legal?
4. Oil catch can - Does this interfere with the emissions side of things or will it pass?
5. BOV - Is the standard one likely to handle 18psi? Or am I better off getting a GT-R one fitted?
Thanks for your help :P
https://www.sau.com.au/forums/topic/319005-stock-by-appearance/
No.
high mount dump pipe won't mount up to a low mount turbo + manifold.
2
Yes, ability to modify a vehicles performance on the move is very frowned upon.
Same as coilovers, since you can leave the pits and wind the boost back up, you MIGHT pass with a manual boost controller, but be prepared to have to take it off.
3
Yes legal, provided you havent hacked up your reo bar.
4
Paint it matt black, use black hoses, etc and you shouldnt have any drama's. No bling.
5
Since you'll need to remove the boost controller, just use a stock BoV over the pits, the revert back to whatever you want.
Get a GTR one fitted later on if need be, say away from massive shinny aftermarket ones, they look and sound like shit.
:P
Edited by Nic_A31
^^ mis read his question.
1: what he said. Downpipe will bolt up to the bottom of the dump pipe no drama's.
2: Depending on who you get they might still see it has a boost controller from looking at the wastegate actuator line. depends how much attention theyre paying. If its all painted black and nothing is standing out, you can probably pull it off, aaand like I said, alot easier with a manual boost controller, no line running back through the firewall.
Do aftermarket dump pipes look much different to standard? It just worries me that when the get under the car they might spot it..
Stock dump pipes have the same texture as your exhaust / turbo housing. Most aftermarket pipes are polished, just go get a can of VHT high temp for headers (about 1000 deg C), about $13 or so, easy fix.
New exhausts are favored at the pits, and aftermarket dump pipes arent illegal (unless they're screamer pipes obviously), so as long as it looks newer than factory and doesnt look like cheap bling shit they'll see it as a good thing.
Heard about you doing this Shae :( They even had a 3/4 week backlog back when I get my first yellow sticker on my old 33 a couple of years ago...way to keep on top of it lol. Danny recommended to a mate to avoid something like this happening (due to the way it is these days with police & any modified import), the best way to go would be a GTR with aftermarket low-mounts tuned for around 330hp. Reliable, not hard or overly expensive to achieve, and for a 4wd car a decent amount of power for the street. Maybe a good option if you sell your car when the reverse-work is completed?
Heard about you doing this Shae :) They even had a 3/4 week backlog back when I get my first yellow sticker on my old 33 a couple of years ago...way to keep on top of it lol. Danny recommended to a mate to avoid something like this happening (due to the way it is these days with police & any modified import), the best way to go would be a GTR with aftermarket low-mounts tuned for around 330hp. Reliable, not hard or overly expensive to achieve, and for a 4wd car a decent amount of power for the street. Maybe a good option if you sell your car when the reverse-work is completed?
Yeah it's a bit of a pain in the arse and wallet, but to be honest my car is a bit of a lag monster at the moment, I was planning to change the turbo anyways. I should be able to get at least an easy 300rwhp, and the only visual bits will be the intercooler, exhaust and pod. The car is otherwise very clean looking and hasnt attracted too much attention.. The only reason I got a yellow was for my BOV and bald tyres which was my own stupid fault (even though it was booked in that week for new tyres :().
What have you got these days Nathan?
You can get the stealth intercoolers which uses the standard piping in the engine bay. The cooler piping and exhaust (if you know what your looking for) is the only thing in my engine bay that points to extra power. Pod as well. Even the exhaust is super quiet, so it's definately possible. That's with the high-flowed tubo and remapped ECU.
Hi, from my experience, an oil catch can is legal if it drains into the sump and the breather is plumbed back into the intake.
Similarly, an aftermarket BOV is legal, if it is plumbed back into the intake - assuming that it meets noise level requirements, which all but a few would with this arrangement.
Regarding the intercooler, there is nothing illegal in WA about fitting an intercooler, as long as you have not altered the car's structure to fit it in (i.e. cutting into your structural cross member or carving up your front bar so that it flaps in the breeze).
Also, there is nothing illegal about shiny pipework. It will draw attention to other mods, though, and may attract a demand for an engineer's certificate and even an emissions test (although the latter is not so much a problem, as the demanding test is temporarily on hold - see other threads).
So, not much to add to what others have said. Hope it all helps. :thumbsup:
Cheers. :)
I went over the pits a few months ago when coppers mistakenly stickered me for my car being too low. I had boost controller in plain view smack bang on the top of my steering column and my apexi pfc hand controller was still mounted to the dash, the guy didn't care. Depends who you get on the day you take it but yes, having a boost controller in the car is definitely frowned upon, and if you do have a PFC controller... hide it heh.
Yeah, I'll have the hide the boost controller somewhere.. I'm also slightly concerned about the test drive, as I have read that the HKS actuator is set at 1 bar minimum? Hopefully the inspector doesnt put too much of a boot in :D
I am thinking I will just leave off the catch can until I pass, not worth having to go over again.
  • 3 weeks later...
Well, went over today and finally passed :P
6k of parts and labour later..
Was dodgy as because my reverse lights only work if I hold the gear lever slightly to the left
All the positive of the day was ruined by getting a speeding fine for 58 in a 60 zone.. the boys in blue are in my bad books at the moment : :)
What? did you actually get the fine or did you just get flashed? If you just got flashed then don't worry about it, they would have just been calibrating the camera. If you actually got the fine... complain!
That's a huge amount of money to spend to get a car over the pits without spending on handling/safety modifications.. seems like the point of actually getting a vehicle road worthy has been lost in the political legislation jungle.. flawed system indeed.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
