i don't think they had obvious markings on them mate.
Well considering the three most common choices of cams in a RB25 heads are:
1. Stock cams
2. Poncams
3. HKS cams
Then you should be able to tell (or post up some detailed pictures and I can tell you since I have had them all) which one of those three they are or if they look like something different.
Edited by PM-R33
He did mention he already has Poncams, installing an adjustable exhaust cam gear is silly, the Poncams have been already engineered for good mid response.
- Adjust your gain setting so the boost comes earlier
- post up your timing map, maybe your tuner was lazy and only tuned from columns 12+ to get you your kW figure and nothing else, you be amazed how many lazy tuners there are out there, that just subtract 5 degrees from the map from rows 15+ and then do a map trace and only tune on full throttle on the dyno
To be 100% sure they are aftermarket cams, pull camcovers off and measure the height of lobe and base circle diameter with vernier clamp.
Aftermarket cams should increase mid to high hp, torque. Can create a bow look to dynograph at lower rpms when cams have enough duration, lift. Also aggressive enough cams should create a lumpy idle (or stock / Tomei cams that had camgears adjusted). Tomei Poncams probably would have a smooth idle and look similar to stock cams, unless you adjust the camgears to make idle lump.
This dynograph shows what happens when intake, exhaust cams are adjusted on RB20DET (should be similar with RB25DET) -
http://www.uniqueautosports.com/Dyno/yx32gtstdyno.gif
Not to be rude but is blatantly clear that the ramp rate was changed for the both cam gear changed run to make it look better.... so the graph is pointless and misleading.
I agree with Ash. I would be looking at the boost controller settings. Most hiflows I have seen go straight to say 18psi, hold 18psi and then drop off at the end. Yours is 16psi at 3500rpm, 17psi at 4500rpm. It just gets over 17psi for a short time so I would hardly say its running 18psi.
Set it up to go straight to 18psi or even a bit higher and then leave it drop off to 16psi near redline. Especially in the lower revs it doesnt hurt to have a bit of extra boost to get going.
I dont think its an exhaust restriction because it still makes good top end power.
i wound the gain up from 19% to 30% (the max setting is 35%), and the start gain from 15psi to 15.5psi. it didnt make any difference as far as the seat of my pants is concerned. i still think its lacking power below 5000rpm.
will look at the other issues.
A whole 0.5psi :(
I know its a bit worrying but the tune should account for a bit more boost. if you are really worried try on a dyno. I would try 17psi so it flattens out to 18psi. will still be the same boost up top.
Edited by Harey
A whole 0.5psi :(
im not worried about running more boost. id happily run 25psi if it made more powah.
the set gain of 15/15.5 psi setting is when the ebc starts to regulate boost, according to the greddy manual. and they recommend setting this for 2-3 psi below desired pressure. yeah i can wind it up to maybe 17 or such, ill try it tomorrow.
would 1 psi at 3500-4500 really make much difference? cant hurt i guess!
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
