hey guys just a quick question.
does the latest stagea come in manual?
i spoke 2 a guy at the importing place in brookvale syd bout the latest stagea and he told me the 3.5 litre stagea comes in manual but cant find them up 4 sale!
does anyone now if they r avaliable in manual?
cheers guys
https://www.sau.com.au/forums/topic/319946-latest-stagea/
do u have any idea on what the car would be priced in oz?
Northshore Prestige is the place that imports and complies the PM35, however they currently only have automatics in stock.
Have a look at their website, might be worth giving ben a buzz and just asking for a typical ballpark figure for the 2wd Manual version.
https://www.sau.com.au/forums/topic/319946-latest-stagea/#findComment-5224081
hmmm interesting....this AXIS 350S seems to have an AR-X front bar and standard grill.
That would be the least of your worries if you bought that car as who would comply it for you?
There is only 1 workshop with the evidence to comply this model and they are only complying vehicles they import.
Cheers
Andy
https://www.sau.com.au/forums/topic/319946-latest-stagea/#findComment-5226011
So this is a misleading advert then? I remember a while back there was then same sort of thing with the PM35's going on with an importer on this forum!
So am I right in saying that Northshore Prestige is the only shop handling the PM35 ATM?
Edited by Jetwreck
https://www.sau.com.au/forums/topic/319946-latest-stagea/#findComment-5226127
"An" importer, aye? lol.
You are correct in saying that Northshore Prestige are the only place you can get PM35 at the moment.
https://www.sau.com.au/forums/topic/319946-latest-stagea/#findComment-5226226
Cheers
Andy
I wrote a little comment to j-spec stating that as far as I was aware there was only one place that could compliance these and that they were only supposedly complying the cars they themselves import. This was there reply
Hi Stephen,
Yep that's absolutely correct unfortunately, they are only doing their own cars so they can mark up the prices massively and make a big profit. They've indicated they will make compliance available to other people later in the year (if someone else doesn't get compliance first).
Regards,
Ben Lippa
J-Spec Imports
Australia:
www.j-spec.com.au
Canada :
www.j-specimports.ca
So, if you brought this car and imported you could well be up the S#1T. Dangerous stuff really, anyway I just wanted to see what j-spec had to say about the situation.
https://www.sau.com.au/forums/topic/319946-latest-stagea/#findComment-5228598
and yet they are advertising them, including an estimate for compliance, and not a whisper on the site about the fact that they cannot organise compliance?
Thats just plain fricken rude!
https://www.sau.com.au/forums/topic/319946-latest-stagea/#findComment-5228615
"Yep that's absolutely correct unfortunately, they are only doing their own cars so they can mark up the prices massively and make a big profit."
And why shouldn't Northshore only comply cars for themselves? I don't see other companies putting their hands in their pockets to get testing done.
Sounds to me like J-spec bad-mouthing because they cannot free-load off Northshore's effort. :D
https://www.sau.com.au/forums/topic/319946-latest-stagea/#findComment-5228810
perhaps j-spec are just quoting how much it would cost by actually placing an order with Northshore...would make sense you would just say I want this car and they would turn around to Northshore and ask them to import it with them acting as a broker almost.
https://www.sau.com.au/forums/topic/319946-latest-stagea/#findComment-5228983
I see whta you are saying, but it wouldn't happen. The price quoted on the website is "landed and complied" through J-spec.
Nowhere does it "break down" the amount that Northshore would have to make in the equation.
Is this car eligible for import?
Yes, we have checked this car and it is a model eligible for import under the SEVS compliance laws.
We have also allowed $2800 for compliance, which is a reasonably typical compliance price available for this particular model.
Also, how would they know how much compliance is for a 3.5L M35?
Just as simple this time as it was last time - if you can't sell it, don't advertise it stating you can
https://www.sau.com.au/forums/topic/319946-latest-stagea/#findComment-5229009
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
