Upgraded ID injectors/fuel rail will see upwards of the 550rwkw it's already produced as well, still retaining the standard head...
We are looking forward to what we can get out of it before the new head goes on that's for sure!!
Traction will definitely be an issue for this car but it will be one hell of a lot of fun to drive!! :)
We (Mercury Motorsport) also have almost completed a JUN 2.7 stroker in an RB26 with an HKS T51 SPL turbo (also in a 33 GTST). Will be interesting to compare the two! :D
  • 4 months later...
What rear housing is on the turbo?
Seem turbo is lazy, 35psi is at 7250 rpm looking at the graph. Check just incase your wastegates are leaking, or a boost leak?
if all ok, id be looking for a small rear housing.
hay mate, its how its tuned, he has given me some drivability. there arent any boost leaks and def not going a smaller rear housing. if anything id go a bigger turbo like the GTX45r, it would be perfect! with the 42r i can short change at 6000rpm and it still hard on boost on the gear change so its very generous on its power band. first thing is first and thats to get rid of the borrowed standard head and put my build one back on. maybe look at a 900hp plus with it all on. which is just pointless anyway.
ta for having a think about it though.
  • Like 1
took it for a run before its got the bigger wheels and wider tires and before it gets this head work put in
did a 11.98 @ 138mph
had it on maybe 40% throttle in 1st and 2nd, any more and it spun and axle hopped then flat foot in 3rd and 4th. but its on the limiter over the line in 4th.
did this on 17 inch wheels so the new 19s will have me still changing hard over the line for more mph and the tires a a 3 year old federal 275, there shit. new tires will we be anywhere from a 305 to a 335 just havent brought them yet so cant tell ya.
  • 3 weeks later...
That is serious rubber.
PM sent.
  • 7 months later...
so how much power rwkw rear will drive can be made wit stock 26 cams - 3l block cam gears and full ported head wit bigger valves , 42r 1.01rear 1000hp
i have pair of timei 260/270 10.25mm lift but if stocks can make over 400rwkw ill keep them in, daily driver vl
gerry
Edited by chairman
  • 1 year later...
  • 1 year later...
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
