Hey, this got me wondering the other day. Called up the tyre shop (Tyre Barn specifically) and asked about the choices on 225/40/18s for my Impreza. They replied with 2 choices: Silverstone Evol8s ($185 each) and Hero Milanza HZ1s ($150 each). I decided to go for the more expensive one as it sounded more legit (probably named after the racing track Silverstone too :)) and i've never heard of Hero at that time. Was getting tyres fitted and couldn't help but to go check out the Heros while waiting. These are the stats i got (forgot the treadwear but they were in the 400 mark):
Silverstone Evol8 (made in Malaysia) $185ea
225/40/R18 92W
Traction A Temperature A
Hero Milanza HZ1 (made in Taiwan) $150ea
225/40/R18 95W
Traction AA Temperature A
So are these tyre readings rated by the manufacturer or as some Australian standard thing? Would i have been better off choosing Heros next time because of the ratings? Anybody with experience?
Hey, this got me wondering the other day. Called up the tyre shop (Tyre Barn specifically) and asked about the choices on 225/40/18s for my Impreza. They replied with 2 choices: Silverstone Evol8s ($185 each) and Hero Milanza HZ1s ($150 each). I decided to go for the more expensive one as it sounded more legit (probably named after the racing track Silverstone too :() and i've never heard of Hero at that time. Was getting tyres fitted and couldn't help but to go check out the Heros while waiting. These are the stats i got (forgot the treadwear but they were in the 400 mark):
225/40/R18 92W
225/40/R18 95W
They are probably named because you need to be a hero to use them, or have huge kahooners :)
I'd say they probably belong on a taxi :P
If they have a treadwear rating of 400+ it's unlikely you'd ever need to replace the tyres....... you'll wrap your car round a tree long before you wear the tyres out :ermm:
Most tyres I use have treadwear ratings around 200 .... you don't get a million miles out of them BUT they keep me on the bitumen :banana:
They are probably named because you need to be a hero to use them, or have huge kahooners :D
I'd say they probably belong on a taxi :)
If they have a treadwear rating of 400+ it's unlikely you'd ever need to replace the tyres....... you'll wrap your car round a tree long before you wear the tyres out :(
Most tyres I use have treadwear ratings around 200 .... you don't get a million miles out of them BUT they keep me on the bitumen :ninja:
Lol trust me it's 400 or 420 tread wear. The only ones with 200 were the normal car tyres (eg. Silverstone Kruzer1). Could this tyre brand be another underdog just like the BC Racing coilovers? (Both made in Taiwan, both very good pricing for performance...)
Edited by TyresBro
I'd imagine if it is going to be for a daily car and not driving it hard around corners it should suffice.
If it meets DOT specifications - the tyre is safe enough for general use.
Just don't expect it to perform if you are an "enthusiastic" driver, ride quality may suffer too.
400 treadwear indicates very hard compound, which translates to poor grip. a higher number its not a good thing.
even the cheap nankang ns2 have a treadwear rating of 340.
^^^This is actually not totally correct.
The treadwear rating on a tyre doesnt indicate how hard or soft the compound is or how much grip the tyre can provide. The only way to judge how well a tyre grips is to use it and judge for yourself.
There are many different factors that determine a tyre's outright grip, like: tread design, tread depth, casing construction, silica or non silica. The tread compound isn't the only thing that gives a tyre it's grip.
Treadwear ratings are also highly affected by the depth of tread on the tyre... For example if a manufacturer made 2 tyres with exactly the same tread compound, design and casing but one had 5mm of tread and the other had 7mm of tread you would have almost the same performance from both tyres but completely different treadwear ratings.
To answer the original question about Hero tyres - they are manufactured by Federal as their tier 2 tyre, they share a lot of similarities in design and construction with Federal tyres and are comparable quality.
I have personally driven an R32 GTST Skyline on Hero Milanza HZ1's and found them to be very good tyres for their price.
The moral of the story? - Don't judge a book by it's cover.
I highly recommend them.
I use Hero Milanza HZ1 tires on my car.
FRONT- 235/45ZR17 97W XL
REAR- 245/40ZR17 92W
I've had them on the car for 20,000 km and there is still plenty of tread to last... actually the tread wear is still nowhere near the replacement marker.
I'm also pushing 250rwkw to which they hold traction fairly well. They're quite decent in the wet too, as long as I don't floor it...
If it helps here's the site for the tyres:
Silverstone Evol8 (Silverstone also makes racing tyres, in different section) (This is the sporty version of road tyres they offer)
http://www.silverstone.com.my/#1274413439156
Hero Milanza HZ1 (Doesn't have their own official site)
http://www.chapelcornertyres.com.au/hero.html
http://www.chapelcornertyres.com.au/files/DataMilanzaHZ1.pdf
Thinking of getting the Milanza HZ1s as daily drive and maybe some semi slicks for track use only :ninja:
EDIT: By the comparison of Hero Milanza HZ1 and Atlanta AR01, i might have gotten mixed up as the HZ1 is 260 tread wear and AR01 is 420 tread wear (both still road tyres).
Edited by TyresBro
  • 6 months later...
I've had the Hero HZ1 on my XR6 turbo for about five months and have done about 6000 km. The tyres are excellent and to be honest, I haven't noticed any difference between them and the original Dunlops in either the wet or dry. Great value for money. Highly recommeded.
Old topic but i have used hero's quite a few times on the back of my car. Similar grip to 595ss. I ran them at 28psi hot and at that they lasted relitively well! Basically on par with all the sub 100 $ tyres imo!
But it just sounds sooo nasty :(
My mate got some replacement tires on a car he was selling awhile ago...po young lol - couldn't even grip his 1st or 2nd in a 180kw wrx (so 4wd!).
And yeah...with your user name, i thought you'd be rolling around in re55s etc!
From what people are saying, it sounds like these hero tires are decentish though
  • 10 months later...
i've had Hero Hz-1's 235/ 40/ r18 Rears and 225/ 40/ R18 fronts on my r33 Si 4 door for over 6 months now and they are really good in the wet.
(I'm running HSD TT coilovers, however being that they are significantly softer ride than TIENS, as they are my base for comparison the tyres are fine.)
The HZ-1 are made by federal as they are a 595 copy.
In comparison to my brother who has 595 rs-r's on the front and 595's on the rear (of his r33 Sii 2 door) they are really twitchy in the wet. And his car is pretty much stock apart from Jap spec Teins.
Im using them on my daily, a commonwhore station wagon.
They work just fine and are not bad in the wet. I would not run them on my skyline but as a general use tyre nothing wrong with them
Thats a good point I have had federal 595 tyres on my car before and they were awesome. I was hoping to go back to them. But since I made a alloy wheel change they didnt come in the size I needed.
Personally 595 would have been a better choice
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
