Got some parts from a recent upgrade to my 2002 R34 GTR, done 63k's. All parts are in Ryde, Sydney, and very good condition:
  • Coilpacks - $100 (also suit RB25 S2)
  • Injectors - $300
  • Cam gears - $50
  • Cams - $200
  • Intercooler with piping - $250
  • Fuel pump - $100
  • Factory dumps - $250
  • BB Turbos (no shaft play and super clean) - $650
  • Front pipes - $50
  • Apexi Power Intake full kit with adaptors (only 2mths old perfect condition, suit R33 too) - $200
  • Xforce split dumps (look identical to my HKS, good welds too) - $250
https://www.sau.com.au/forums/topic/320772-gtr-and-other-skyline-parts/
No sorry dude.
Interested in both dumps,stock cooler etc.please sms/call me on 0433 878905 to discuss further.will be at Eastern Creek for the super lap on Saturday
Alex
www.jds-auto-imports.com
Parts updated as follows:
* Coilpacks - $100 (also suit RB25 S2)
* Injectors - $300
* Cam gears - $50
* Cams - $200
* Intercooler with piping - $250
* Fuel pump - $100
* Factory dumps - Sold
* BB Turbos (no shaft play and super clean) - $650
* Front pipes - $50
* Apexi Power Intake full kit with adaptors (only 2mths old perfect condition, suit R33 too) - Sold
* Xforce split dumps (look identical to my HKS, good welds too) - $250
All others remain. Currently OS, let me know what you need and will see if i can organise shipping, though pickup certainly possible.
Pump still here. Turbos still here sort of.. They are ceramic, only N1's are steel.
  • 1 month later...
  • 3 weeks later...
  • 5 weeks later...
* Injectors - Sold
* Cam gears - $50
* Cams - $200
* Fuel pump - $100
* Front pipes - $50
Some parts are neg.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
