Hi ya all,
It has been 6 months since the last pie run so i thought we should get back on the road once again. It will be same as the regular run that we do.
Meet at 10.00am at KFC carpark, Cross Roads, Casula.
Head off at 10.30am Sharp
Head down the Hume Hwy for a while then turn left as though we are headin to Woolongong.
Conitue along (dont veer into the gong just keep going straight)
Continue down the hwy until we reach a great big roundabout. Turn right at the round about and follow rd for a bit. Then turn right at the lights and follow it all the way up the mountain:)
Get to the mountain enjoy yummy yummy pies and check out each others cars:)
Distance: 115.8km Time: 1hr 19min (approx)
Travel: Fastest (with tolls)StartCrossroads Homemaker Centre
Continue along Hume Hwy, Glenfield36.5km8.
Veer left onto Picton Rd Exit, Wilton0.7km9.
Continue along Picton Rd, Wilton27.3km10.
Continue along Mt Ousley Rd, Cataract5.3km11.
Continue along Southern Fwy, Mt Ousley at University Of Wollongong18km12.
Continue along Princes Hwy, Yallah2.6km13.
At the roundabout - take the 2nd exit onto Illawarra Hwy, Albion Park Rail4.6km14.
At the roundabout - take the 2nd exit onto Illawarra Hwy, Tullimbar19.7km15.
Arrive at Illawarra Hwy, RobertsonSub Total 115.8km
1hr 19minEndIllawarra Hwy, Robertson, NSW 2577
I will keep a close eye on this and as we normally have quite a big turn out to this i will ask for a few drivers to nominate themselves as group leaders to ensure no one misses that turnoff that we seem to have problems with each time we head up there. I am hoping we get a great turn out and remember, All vechiles are welcome to come along just so long as they follow the ethics and rules that SAU promte at all times.
You have a whole 4 weeks to be planned and ready, make sure you take the time off work and put it on your calendars:):cool:
See you there
  • Replies 150
Ill also be letting the local police know that we are heading down on a friendly cruise and i will be asking for a gold coin donation from all drivers and the passengers as a donation to the RSPCA.
We shouldnt have troubles in this case:)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
