My suspension is very stiff. It's fitted with Arigostas, they were on the car when I got it.
There is no markings for their spring rates, but it's the type where you simply do not want to hit any potholes period.
I've never been in another GTR to compare, even a stock one, so I don't know how stiff they are supposed to be, but my RX7 was alot softer, and still very good handling.
I assume a few people have pretty stiff suspension, it's the kind that makes panels rattle and even your keys fling around when you hit a pothole.
I see a lot of setups using 8kg front, 6kg rear. Does anyone use these? Say, the BC ones from Just Jap? - I love the Arigostas for handling, but they simply aren't suitable on a street car.
Too many people confuse stiff suspension with good suspension.
Stock R32 Gt-R spring rates are
front 2.4kg/mm
rear 2.7kg/mm
Pissing competitions about spring rates & how high they should be are about as useful as those centreing how much rim/tyre you can stuff under a guard.
Anyway for what it is worth I run 5kg/mm front, 4 rear. Nismo stuff is half a kg/mm higher at both ends. With the right sway bars that is enough spring for the track on R compounds. It is also a reasonable rate for the road.
If ride quality is important to you then I would avoid a rod end castor rod & get something with a decent bush in it.
I had 10kg/8.5kg and hated it. I now have 8/6 and its much better (though they may also be related to adding some ride height), though i think a little softer would suit me best (and i like stiff suspension).
I'm running approx 5 / 3.2 in an R33 GTR. I find it a little hard but the dampener has plenty of adjustment that I can play with and it seems to make quite a large difference.
Ride quality is pretty good except on rough roads...which they're are plenty of in Melb :)
Car handled excellently at Sandown, Centreline was quite impressed and thought I was running semi-slicks when I was running some compliance tyres :P
R33 GTST. 10s and 8s = Crap on most roads, great on track. All depends on how much of each type of driving you do. Personally i think these are a bit stiff.....
Even race cars need some degree of compliance, although usually they have better dampers which helps.
front 2.4kg/mm
rear 2.7kg/mm
What is the reason for the higher spring rate in the rear? The Nismo S-tunes I had were like that and the Bilstein PSS9 kit that I got had similar slightly stiffer at the rear. Obviously everyone is aware of the awful weight distribution of a GTR there must eb another underlying reason.
Generally a softer spring generates more grip at the end of the car it is fitted to.
On the road you don't have the same level of issues typically found on the track with things such as weight transfer etc. So you can get away such low rates.
Track cars typically need softer rear springs (relative to front) to help with traction. This is at the price of front grip & is why most track R32 Gt-r's run alot of front end neg camber, stiff rear sway bars & softer front sway bars.
Excellent info thanks. New springs are definitely the answer when it is time to hit the track, would 8/6 front/rear be a good starting point with a decent semi-slick? Obviously there are other factors but in general.
I reckon they are too high for an R32 Gt-R.
If you have a look at the rates Nismo recommend you can't go far wrong.
For me 5/4 is good 5.5/4.5 is good too.
But as I said you need to look at three things in conjunction with this.
1 How well is the ATTESSA system working (eg do you have a controller - if you do you can arguably run a higher rear rate relative to the front.)
2. You need to address the front & rear camber angles.
3. Sway bars are needed too. Good swaybars at that.
Interesting. Yeah mine has the adjustable dampers but it just goes from stiff, to stupid stiff.
When you jack the car up the wheels lift off the ground about half an inch after the car, when you pull into deep driveway drains at an angle the car will teeter on the 2 corner wheels, sometimes I have to roll back and get a run up (especially noticable in 2WD when I had my shafts out).
I don't think it's an issue of being a girl, it's that stiff it's putting stress on the car. I can only assume they are 9+kg. I simply want to replace the whole set.
Where can I obtain coilovers with ~4-5kg rates? I only find 6-8's, and higher.
Edited by GTRPowa
Is it a 32 or a 33? Your thingo says a 32 but the post a couple previous says 33.
Again look to the Nismo rates for the thing. You will see the rates on a 33 are harder.
It's a 32, I didn't notice I indicated anywhere I had a 33, but nah only a 32. It just does my back in.
Apologies, I hijacked the thread a bit... I have a 33.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
