Hey i have been told that my gasket is leaking between my exhaust an turbo. The things i wanna ask is Leaving this too long will it result in future larger problems? How long will it take for a mechanic an How costly will it be? An If There is any stud problem how much is that setting me back also?
Cheers
https://www.sau.com.au/forums/topic/321554-turbo-exhaust-gasket/
i had this on my 33 when i got it needed gasket from turbo to exhaust and gasket from head to exhaust, and studs where sanped in head tho. and to pull every thing off then get studs out put it all back in with all band new studs and new gaskets, it was a all day job morring till dark ,1st time i had eva done that on a skyline too . but i am no mechanic hope that give you a idea of how long it might take
this happened to me on my r34 gtt aswell.. when they were changing my exhaust to a full turbo back he discovered it.
do u have bad fuel economy atm? i got told it wouldnt do the turbo much good if i left it like it for too long and it have abd fuel economy. i had it fixed straight away as the exhaust was already coming off...
Is it the exhaust manifold to turbo or the turbo to downpipe? either one is relatively simple and 800 is definately a rip off! You would only really need a socket set and turbo bolts are not too bad. Drop exhaust pull of intercooler and intake pipes undo heat shields and unbolt turbo, don't think you will even need to remove banjo lines should be able to slide turbo off and on if its that one.
A while ago when I didn't bother doing my own work i had the manifold to turbo gasket fail, i had the problem found and fixed as well as having my cambelt changed for $550
Exhaust manifold to turbo i believe. Yer but you need stands ect or a lift.
All that has to be done is take heat shield off undo the bolts that hold the dump to the turbo. Gasket comes out. Replace with new one and that's it. Would only take about 30mins to an hour for an exhaust shop to do it. I've replaced my dump/front pipe and that only took me about an hour to do myself.
Mmm, How much work is under the car? Just for the gaskets? An did you use some sort of stands for the front/dump pipe?
you can get away without taking dump off. in fact all lines except oil return can be left on turbo. remove heatsheild. undo turbo bolts... lift up. remove stuffed gasket and fit new one. refit nuts and torque up... done
This has happened to me too. But instead of removing the turbo and putting it back on I'll chuck a new turbo on.
Question is about this torque up thing.
I couldn't get a socket onto the nuts, this normal?
and anyone know the correct torque settings?
This is true. It is very easy you have enough room to play with to fit and remove the old gasket.
yeah 17mm spanner usually is the go
FT specs is what i do em... as tight as i can get them and then use those locking tabs.. never have an issue
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
