Hey peeps,
I have to sell a bunch of stuff that will be VERY useful to anyone complying R33's.
So check it out.
There are the following parts :
Set of near new Ohlins fully adjustable suspension for GTR
Set of VGC Tein Greenies for gtst (sorry sold this afternoon! 11/03/04)
Set of Volk Racing 18" mags (8 & 9 inch) Same guy bought these as well!
Set of 18" Manaray's (8 & 9 inch) $2200
3 sets of R33 GTR rims $1600
2 x GTR frontpipes $150
2 x GTR steering wheel with airbag $700 each
2 x sets of GTR suspension $450 per set
1 x pair of GTR mirrors $130
GTST airbox $100
Used GTR Engine mounts $140 each
Used GTR Brake pads (brembo) $300 for each end
I have a few other bits and peices lying around as well, so let me know what you need, plus I get stuff in from Japan from time to time, so I can help out if you have a drama. Just PM or email for more info & pics.
Thanks
ENJOY!!
https://www.sau.com.au/forums/topic/32161-r33-gtr-and-gtst-original-parts/
  • 1 month later...
  • Replies 48
Hey Dude,
Do you have a black GTR wing by any chance? Im looking for a GTR wing for my car. Also the GTR rims how much are you looking at selling them for?
Hi,
Have an original R33 GTR wing on its way - will be here next month. Price is $300, will send pics when it gets here, as it's in a container now.
Rims, brand new as I got them to comply my car...
Don't have tires, but you can have the rims for $1500 for the set. Can get tires put on for $250 each.
email me and I will email you pics if you want.
Thanks
Do you have any coilovers, shocks or springs for R33 GTS25T? Also looking for a white S2 rear spoiler or GTR wing. How much for these?
No and yes...
No for the gtst coilovers
Yes for the GTR wing - $300 (it is original - not a copy - got it from a GTR shop in Japan.)
Coming in a container now, so will be available from Mid April...
Thx
how much you want for the ohlins?
and are the front pipes stockies?
Ohlins are $3000 ono in near new condition (they are worth 800,000 yen new - $10,000 - in Japan I have been told...)
Yes, I have 2 stock front pipes for R33 GTR and some aftermarket ones on the way in a container... $190 each for the stock ones, afters should be about $320 each.
Prices are plus freight or pick up from Brissie....
Thx, Ads. 0412 631 081
OK, I only have 3 original GTR wings, but I have a mate who makes really good copies. Both GTR and the wider Nismo version...
I will ask him what it will cost to make the copies (that are exactly the same as the originals, but made of Fibre Glass...) so is FRB OK??
Hope I can help you guys out...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
