LOL nice work with the photos..
Sorry about your loss.. What's his user name? I'd talk with the mods on here/boost.. i think they deal with each other on ip addresses etc to ensure he's not on here also.
EDIT. Paste a link to his thread in here also.
Edited by .:: GimpS-R34 ::.
man that guy looks dodgy.
sorry i have nothing constructive to comment but MAN he looks dodgy.
I guess Mr Eps...
There are some animals only mothers can love...
http://www.ezzal.com/wp-content/uploads/20...-rhino-copy.jpg
Ahh this old chestnut, he has a very very long history of ripping people off, big thread on it in the QLD section. Seems odd though, he does legit deals with some (including some people i know personally) and totally screws over others!
when heroin is not needed - legit
when heroin is needed - not legit
You don't have to be a member.
But it looks like this guy got what was coming to him once before, this guy tracked him down notified the police and took him to court, he got all his parts back.
http://www.rexnet.com.au/forum/index.php?s...t&p=1632614
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
