See you guys at 9am!
For those attending but not in the car display or shopping in Repco, please park in the Bunnings carpark around the back, as not to clog up the small carpark which other business's use - this will be strictly enforced.
Nigel.
bunnings?!?! can i be an exception? you all know you wanna stare at my engine bay!
  • Replies 78
Posted Images
i'll come for a peek after lunch
save me a snag damo :sick:
+1 Save me a snag too.
Car is getting detailed as I type this ... waiting for Stag to be returned. Might ride up on the Brutale if its not finished soon.
Also finishing off the fences in my front yard. Out with the 1.5m, in with the 1.8m :action-smiley-069:
Yeah was a good day .... thanks to Ben & Steve for organising most of it, thanks to all those who helped in their own little ways, and special thanks to Sam for helping me cut up about 1,000,000 onions - my hands still stink! :blink:
good times today. good to put some faces to names....
can tell steve knows his way around a sausage :)
cheers to Nigel & Ben for organising it.
not sure if u guys heard me leave, i had some traction issues
i saw this black thing leave just before i arrived
bit wet wasnt it :)
We saw nothing :banana:
bit wet wasnt it :)
i blame the state of the roads in SA :thumbsup:
had a fun drive home via the hills, camber wear made it pretty hairy though... i gotta get that thing outta the shed more
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
