sorry about prev post ... posted reply before i could edit it.
Hi Mark , did you consider the OMP WRC carbon - $2889.
I am thinking of going toward that style seat or racetech equivalent. The higher head restraint maybe a hinderance on the road. Since the defender already has lateral head support i dont think the head blinkers adding anything to the safety, just the price?
Have you got any current info regarding the airbag sensor plug in 2.2ohm resistor.?
As the Nagtroc link has its detailed info deleted. I asked the guys at Nissan can I buy the yellow plug and they said can only buy the whole wiring harness for the seat.
OMP HTE Carbon went in today. trial fit in the car tonight.
the centre tunnel of the car is asymmetric ( I assume to accommodate the front drive shaft), sticks out more on the driver side on for Aus cars which is a pain in the arse.
all airbags are stripped out so not worried about the sensor light!
probably will paint it but have other things happening over the next few months that will require the bumper to be removed, as well as having other carbon pieces to fit that will all need painting so makes sense to do them all at one time.
Dear Person,
STFU
Kind Regards
lol internet is serious business
Makes sense to me. I was really just wondering if that was the plan. Keep up the good work. Car is coming together nicely.
  • 5 weeks later...
  • 1 month later...
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
