yep i meant guards.
I dont see why they wouldnt bolt straight up, as you say - same chassis.
but still, do a bit more searching through the forum dude, this has been covered plently of times and i'm sure others here have done it
if its the s2 front bar in particular that you really like - you can install this with the s1 front end. I've seen it done before with my own eyes.
as for series 2 front bar on a series 1 was it straight fit?
Couldnt really tell ya sorry mate. It was on a friend of a friends car, and i dont reckon the guy installed it himself.
If the s1 and s2 reo bars are different; this will obviously need to be swapped.
I wouldnt think it would be too much stuffing around. Front bars are generally pretty easy to install with all the right fastening bits and tools. OEM items in particular are always better and straight forward compared to aftermarket fibreglass copy junk.
S1 bar wont fit a S2 bar apprantly.
I went to buy a GTR copy for a GTS-T S1 and the seller told me it wont suit my car (S2).
I think you'll find the only reason this GTR copy bar couldn't be swapped from s1 to s2, or vice versa, is because the grill between the headlights is integrated into the front bar.
This means that the different shape of the headlights will cause a drama.
However, a simple standard s1 or s2 front bar separates the grill, and the top of the bar is completely flat. Regardless of the headlights, they should both fit. Don't hold me to that, it may be that simple things like bolt hole positions etc are wildly different, especially if the front reo is different, but judging by the overall shape of the two, I'd bet the front bar alone IS a straight swap.
If it's the headlights you're after, however, THEN you're gunna need grill, bonnet, quarter panels, headlights, a truckload of cash for shipping costs......
experience right here.
You will need a
S2 front bar
S2 re enforcement bar
Grille
Bonnet
Headlights
YOU DO NOT NEED FRONT GUARD (they are exactly the same S1 and S2)
If you are doing it with a r33 S1.5 (1995 model, without fog lights) you also need the fog light stalk, fog relay and you have to change the connector plug into the indicator/fog light unit as the non fog light plug is too small. (The car is wired up for foggies no matter what model, its the blue wire out of the 3 wires going into the indicator/fog lights)
Thats all you need mate :)
You will need a
S2 front bar
Grille
Bonnet
Headlights
will he need them just to change the front bar though? i don't think he does as the front bar is flat at the top and shouldn't make a scrap of difference to the headlights. if he wants to put the whole s2 front end on then obviously he will, but if he only wants to put the front bar on then he shouldn't need them, or it wouldn't be hard to make it fit without them
Yes thats right. If you juts wanted the front bar you could change the reo and bar and be done with it.
i'd say no to the above question. also, because of the different shape of the lights on the series one, the lights will be sticking out a little bit over the top of the s2bar if you dont go s2 lights. hence why its better to do the light swap too if you can afford it
  • 1 year later...
  • 3 weeks later...
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
