Was the spigot bearing an original Nissan part? Why did it fail, just through wear and tear?
No Matt, it was a needle roller bearing one, lasted all of 20 mins due to input shaft nicking it when we went to fit gbox. After that, I'm only ever fitting stock bronze one's ;)
Thanks Charlie, it feels good.
Next will be a set of bilstein coilovers :thumbsup:
Thanks Brad! Yours will be a monster!!
Still have not done clutch...had to keep it on the road due to things popping up and arriving short notice :whistling:. Was worth it though!
The clutch is a Nismo gmax twin plate (Brett) , that I got second hand, cleaned, inspected and rebuilt with new clutch discs.
I'm currently half way through getting brembo bits to take the brakes back to something more streetable...
New scuff plates..post-12712-0-88248000-1327199816_thumb.jpgpost-12712-0-09787700-1327199833_thumb.jpg
Nice scuff plates mate.
Want to sell me the stock ones, if they are in good nick? PM me.
  • 1 month later...
  • 3 months later...
Is going okay Matt, but I always want more....
Have got a couple of things for it recently:
Some tein bonnet struts.
Also got some bilstein PSS9 coilovers. Only issue is that one of the front coilovers didn't have the fitting kit (nut, spacer, rubber and adjuster knob) with it so I can't use them yet :(
Will have to get that sorted asap.
Over 2k.... no adjustment spanners, and missing a fitting kit.
Fitted some new tein super streets to Karcher's 450sx. Went in no worries and handles way better and feels great on the road.
damn, sounds like an annoying buy. PSS9's are normally cheap though, there's a set selling atm too!
http://www.skylinesaustralia.com/forums/topic/407326-rays-volk-re30s-bilstein-pss9-apexi-pfc-nismo-blitz-etc/
  • 1 month later...
Over 2K without top hats?
Yep....
The -9's are sold...
So...Stage 2 has begun :D
Consisting of:
tomei 2.8 stroker
GTX2860 turbos, -5 turbine housings.
HPI dump pipes
new nismo Coppermix twin plate clutch and flywheel kit spec c
block partial grout filled decked, torque plate honed etc..
port and clean up head, tomei type b springs.
Ross trigger balancer and kit
And lots of little cool stuff....
such as nismo style tail lights
I aim to get this done and all on the road for SAU nats in November!!!
Pulled engine out today.
Already have a block getting prepped to save time.
post-12712-0-35830300-1349268972_thumb.jpgpost-12712-0-75074700-1349268974_thumb.jpgpost-12712-0-59271900-1349268979_thumb.jpgpost-12712-0-20193100-1349268983_thumb.jpgpost-12712-0-97933900-1349269005_thumb.jpgpost-12712-0-40106300-1349269037_thumb.jpgpost-12712-0-19736800-1349269064_thumb.jpgpost-12712-0-99577100-1349269095_thumb.jpgpost-12712-0-26416400-1349269138_thumb.jpg
Can't wait to see this done and running!!
Awesome list of parts HPI dumps are awesome and Nismo clutch even better I have both hahaha
You forgot a certain carbon snorkel ;)
That is on the way too!! :)
Nismo snorkel from RHD
Holy shit this is gonna be a big change from the -9's on stock rb26
Goodluck with it mate can't wait to see it all done and out and about !
Thanks!
Shit is getting real!!!
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
