What Col said. Assuming it's to remain a street car, check for legality before you spend a cent.
If you absolutely must go ahead with it - and I really hope you don't, personal preference I guess but I hate scissor doors - then places that handle Autosalon-style cars would likely be your best bet. Check any Hot4's/Autosalon/Fast4's/whatever mag for feature cars with the body mods you're looking for - there will usually be contact details for the shops that have done the work alongside the story. Doing it properly won't be cheap though.
https://www.sau.com.au/forums/topic/323155-scissor-doors/#findComment-5268624
It is illegal unless u can get an autorised engineer to install and approve them in written form, but because the are considered dangrous according to the government it is doubtful u can get it legal since no engineer will approve it. but u can put them on and hope you dont get done..... i know that taking them off is much harder then putting them on. doesnt matter if its bolt on or not you need to have it welded to ensure it sits in the right place.
You can get these online and shipped otherwise hit up some body shops i know some can order them in.
https://www.sau.com.au/forums/topic/323155-scissor-doors/#findComment-5268740
I thought Lambo first invented sizzor doors so you could reverse their stupid designed car and actually see where your reversing (open the door and stick your head out) without having the worry of a horizontally opening door.
It was easier for Lambo to do this then redesigning the whole rear of the car.
Sizzor doors on Lambo = Stupid manufacturer after thought.
Sizzor doors on anything else = EPIC FAIL
https://www.sau.com.au/forums/topic/323155-scissor-doors/#findComment-5269210
Your almost right...
It was actually cause the wheel track was so wide, it enabled people to park a lambo in a stnadard car space and still get in and out easily...
This however didnt help the normal cars parked either side and would probablly end up with door dints cause thy were so fat*...
*fat = wide... not phat or awesome...
https://www.sau.com.au/forums/topic/323155-scissor-doors/#findComment-5269729
LOL!!
Awesome and welcome to SAU
https://www.sau.com.au/forums/topic/323155-scissor-doors/#findComment-5277713
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
