The ambient temp sensor in my cars climate control reads -30 degrees all the time, which means the blend door doesnt close all the way to let cold air through when you set it to 18 degrees because it thinks it's -30 so obviously it wants to warm you up because it thinks youre freezing to death, this is giving me the shits majorly as there is always hot air coming from the vents.
Just wondering if anyone knows where the sensor is or where to get a new one, havent bothered to pull it all apart yet. I'm an auto elec as most of you know but surely someone on here would know more about this particular system than i do.
Any info would be great.
https://www.sau.com.au/forums/topic/323180-r32-ambient-temp-sensor/
I wont go to the trouble of wiring in resistors, i also found out if i hold down the cooler temp button it switches to FC (freezing cold? lol) and that closes the blend door all the way. So that can be a kind of temporary fix for now as im not too concerned about not having cold air atm.
When i get time ill have a fiddle with the temp sender.
Thanks guys
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
