  • Replies 146
Posted Images
So its a different car since since the 1.19 and even then I was only allowed to do 4 or 5 laps till they sent me home.
Since then the setup was changed to get the low 33 at Winton.
Over the coming weeks im chucking the wing on and tweeking it up a bit. Sadly the gate will have to be plumbed up ;) No more cow bell at Sandown Bris
Plus the super special Yokie will add a second im sure.
Defiantly a low 18.
Weather permitting it will have to be the John Mott sprints in July
- Roll Cages - Must be CAMS approved
- Bonnet Catches - All rear-hinged bonnets must have an additional independent non-flexible strap fitted. Permanent straps/pins attached to the bonnet are not necessary. It is acceptable to tie the bonnet down with light rope. Bonnet Pins are also accepted.
Under Vehicle Requirements are these two items necessary for every vehicle entering the event or only if you have them already then these rules apply.
yes that is cams... from what ive seen go through scrute, the cage doesnt have to have a cams sticker or anything on it.
just meet the cams requirements. its upto the guy going through your car on the day. if you get a hard ass scrute, then tough.
and yes you will need an additional restraint. the double system on post '89 (?) bonnets passes sometimes...again depends if you
get a scrute with a pole where the sun dont shine...they will want an independent restraint. (bunnings is across the road, i know from experience...)
if you dont want to screw around and argue with the, great, fantastic work :P the scrute do on the day.
drop into bunnings and get parts to make one of these up http://www.skylinesaustralia.com/forums/Se...onnet+restraint
Ok the bonnet strap is easy enough. There is one thing I find confusing and that is whether or not you need a roll cage to enter these events? Based on what was said at the start of page 2 you don't, but reading through the vehicle requirements it says you do?
I have paid to enter this event and I don't have a roll cage in my car. Can you enter without a roll cage?
yes you can.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
