  • Replies 191
GONE!!!!!!!
is it an interesting pic? no, but it's first up for the month. Is it artistic or creative? Not really, but it's here and it was taken in june.
Renovators dream! ahaha
yea i have a few pics i took yesterday but currently doing a virus scan on the home PC... its slow as dog poop
took these yesterday morning...
should watermarks always be in the same position????
This isn't a june capture... but I did only find it in june :D
Anyone know of a photoshop script that will throw a few basic bits of info from the EXIF/Metdata into text layer on your image???
Or even a way to extract the EXIF/Metdata into text document or selectable text? I could type it manually but thats hard work ;)
thought it could be interesting to post up the photo data for people to reference...
Edited by barraspalding
Nope :D
Not sure about PS but once its on the web its easy. With Firefox and the FxIF Add-on
you can simply right click on photo and go to properties and then get all this (this is from your bike photo):
Camera Maker: NIKON CORPORATION
Camera Model: NIKON D40X
Lens: 18.0-55.0 mm f/3.5-5.6
Image Date: 2010-01-31 23:20:24 +1000
Focal Length: 26.0mm (35mm equivalent: 39mm)
Aperture: f/25.0
Exposure Time: 98.000 s
ISO equiv: 100
Exposure Bias: -0.67 EV
Metering Mode: Center Weight
Exposure: Manual
Exposure Mode: Manual
White Balance: Manual
Light Source: Flash
Flash Fired: No
Color Space: Adobe RGB (1998)
Mr. Oizo you've been holding out on us!!
These were taken last weekend but only got a chance to look at them tonight
This is a shot of my Hilux the day after installing 2" lift Ironman leaf springs and
new Ironman shocks in the front. The rear have not been done when this photo
was taken.
This is a shot of my friend's Landcruiser with his new 33" mud terrains.
Both shots were taken with my 18-70mm kit lens while out driving in the
National Parks near Nambour Queensland.
this is from may, but i'm posting it in the june thread because i'm already here lol
nws:
http://www.flickr.com/photos/tharakalol/se...57623967400403/
Very good shots in there :) Great control of the lighting. Tell me more of the setup!!
thanks sidd
generally it was pretty much like this:
the ones in the cyclorama with emily marilyn and the bed were using a big gridded beauty dish as the main light
and the ones that are much brighter all round, and a bit more "high key" sort of, are the gridded beauty dish as main, and a softbox on the left as fill
the ones in the little room with the checkered floor had a diffused beauty dish, camera right as main
and a softbox, camera left as fill
but as i moved around for some shots, the 'camera left'/'camera right' thing gets a bit muddled around
It's the harbour bridge nick.
Oizo do you have any pics of your set up? sort of like a behind the scenes ;p I really want to get into people pics and have basically a 0% understanding of lighting tools. P.s. Send me scantily clad models to practice with.
here's the cyclorama with the gridded beauty dish, there was a big softbox on the left
and here's the other room
you can see the softbox on the left, and the diffused beauty dish on the right
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
