  • Replies 191
matboy - Its in alexandria.. Oh loving those shots of the classic car :)
haysey - man so jealous!!! post up more photos ;) How long you over there for??
lepper - hahah man you really getting addicted to HDR uh? Its good tho, and not overly done. Fisheye one is great.
bnr#@ - you did a wonderful job tho ;) panning at night must be very hard.
Haha yeah, i got more shots of the pelicans. Biggest farken ones i've ever seen!
Will post up tonight. I think my SS was about 1/1600th, you can see the rain lol. Didn't even notice that before.
Bangaz Boy - Sweet photos mate!
If i were you, i would tone down on the HDR processing on your car. Everything else is fine, but especially with your car being black, reflections are killing it. Possibly use a layer mask and the original image and merge them together, with the HDR being the background and everything and the properly exposed car in the photo instead of the HDR composite.
Do you know what i mean?
Yeah mate I know what you mean :D. At the time i was going for the reflections as I wanted to see how it came up after processing it as a HDR (went a bit overboard with the processing). I've been wanting to try a few of the car with the polariser to cut down the reflections to see how it would look, unfortunately car is off the road at the moment. Otherwise I might try give the layer mask a go, really need to improve my PS skills. thanks for the tip!
I agree with kory, tone down the hdr on the car. If you've got the original pics just cut your car out and paste it over one of these. You can just adjust the tones and shadows of your car to help it blend in.
the animal shots and waterfall stuff is all fantastic mate! 10/10.
Thanks for your comments guys, I like receiving constructive criticism, trying to improve as much as possible, so feel free to give me any advice or criticism. Otherwise I'm glad to hear that you guys like some of the photos.
Barra - I know what you mean about HDR, everyone seems to be doing it these days, and there is a lot of overdone stuff (including stuff I've done). I've only recently just got my camera so I've only just got into doing the HDRs and having some fun with them. I really want to improve on standard photos instead of relying on HDR to make them standout.
Well in that case!
Cool image - might be better with bigger DoF? Not sure where I should be looking.. maybe darkening the surrounding plants and leaving middle one to be brighter
Very very flat image - needs darker darks and brighter brights (very common HDR problem due to the nature of HDRs)
Don't think the horizon is flat but it works in this image imo
That is freaking amazing. Very impressive. Just need an interesting foreground and it would be super.
Another nice one.. don't think the non level horizon works in this one though
These two are also very flat
Background slightly flat. I don't mind the HDR car but the halo's around it aren't nice
This one is perfect I think. Only thing I would do maybe is crop the bottom and left slightly.. maybe
Good shot - like the teeth
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
