I recently changed my gearbox oil (manual) for some synthetic shell oil (75w90). the box is a lot worse to use now. i can't change into 2nd properly when cold (grinding noises) and every gear is a bit 'notchy', sometimes even when warm.
now i read in some thread that when changing from mineral oil to synthetic oil in the gearbox, sticky deposits can be formed on the gears which make the gearbox hard to use. i think this is my problem.
I was considering putting half a bottle of the engine flush stuff into the gearbox before draining it to see if that helped...is this safe to do? or is there a more conventional method of flushing the gearbox?
or am i completely wrong and something is wrong with my clutch (ie not fully disengaging)?
thanks
Greg
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/
Hey greg, maybe coz the oil grade is 75-90? its slightly thicker than the old stuff u had in there? I wouldn't put any of that engine oil flush into ur gearbox, dunno if it does any damage or not but i don't think any ones tried it before. not too sure what kinda crap is in that flush fluid.
are you changing the fluid urself? or taking it to mechanic? lol, coz i need to change mine.
I think that you should drive the car for a few more k's, and then after that change the oil again with that synthetic stuff.
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-648384
hmm the owners manual say to use 75w90...but i get what your saying, an older/worn gearbox needs thicker oil. changing fluid myself. its easy to to do, GenesisR32 posted a great thread DIY thread, its in the FAQ section :D or i can show ya if you want. thanks denny :)
try using Nulon G70 instead. its great stuff! i had the VMX80 in mine but felt alot smoother with the G70 in it 3 weeks later.
if that fails, then do the flush but i wouldn't recommend it though.
yeah i put a tube of G70 in...it made a bit of difference but its still really crunchy when cold. i might try this VMX80, everyone seems to speak highly of it. if that doesn't work then its redline time. if that fails then gearbox rebuild time lol :D thanks mate :D
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-649232
Vmx80 + G70 = :D
redline oil = :D:thumbsup::D but expensive
the VMX80 takes a while to run in when you put it in the gearbox and i noticed that its highly effective only warmed up properly but like you, i did experienced some crunching when cold. when i added the G70, it became a whole lot smoother regardless of hot AND cold.
dun you feel your arms muscles tightening up everytime you do the filler and drain plug?? :)
i used the redline stuff in my diff instead. :)
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-649343
Sorry GenesisR32, I disagree. Nulon G70 is the biggest load of crap I have ever put in my gearbox. The shit is TOO slippery. My synchros started behaving in ways that resembled a slipping clutch.
I too had Shell Synthetic 75w90, which I feel comes along side the Nulon additive as being the crapiest gearbox oil on the market. As soon as I changed the oil to Shell, the shift from 1st to 2nd was hell worse. I then added the Nulon additive, the shift was still crappy and I started having synchro problems. I drained the crap (Which now looked like cows milk thanks to the Nulon additive) and replaced it with VMX80, bled the clutch...Perfecto! (well nearly) The 1st to 2nd change is significantly smoother, even in the cold. Oh and so far, no more synchro problems...touch wood! The stupid thing is that the money that I have spent so far in this little episode, I could have used RedLine Shockproof for the same money...oh well...you live and learn.
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-655395
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
