I recently changed my gearbox oil (manual) for some synthetic shell oil (75w90). the box is a lot worse to use now. i can't change into 2nd properly when cold (grinding noises) and every gear is a bit 'notchy', sometimes even when warm.
now i read in some thread that when changing from mineral oil to synthetic oil in the gearbox, sticky deposits can be formed on the gears which make the gearbox hard to use. i think this is my problem.
I was considering putting half a bottle of the engine flush stuff into the gearbox before draining it to see if that helped...is this safe to do? or is there a more conventional method of flushing the gearbox?
or am i completely wrong and something is wrong with my clutch (ie not fully disengaging)?
thanks
Greg
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/
Hey greg, maybe coz the oil grade is 75-90? its slightly thicker than the old stuff u had in there? I wouldn't put any of that engine oil flush into ur gearbox, dunno if it does any damage or not but i don't think any ones tried it before. not too sure what kinda crap is in that flush fluid.
are you changing the fluid urself? or taking it to mechanic? lol, coz i need to change mine.
I think that you should drive the car for a few more k's, and then after that change the oil again with that synthetic stuff.
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-648384
hmm the owners manual say to use 75w90...but i get what your saying, an older/worn gearbox needs thicker oil. changing fluid myself. its easy to to do, GenesisR32 posted a great thread DIY thread, its in the FAQ section :D or i can show ya if you want. thanks denny :)
try using Nulon G70 instead. its great stuff! i had the VMX80 in mine but felt alot smoother with the G70 in it 3 weeks later.
if that fails, then do the flush but i wouldn't recommend it though.
yeah i put a tube of G70 in...it made a bit of difference but its still really crunchy when cold. i might try this VMX80, everyone seems to speak highly of it. if that doesn't work then its redline time. if that fails then gearbox rebuild time lol :D thanks mate :D
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-649232
Vmx80 + G70 = :D
redline oil = :D:thumbsup::D but expensive
the VMX80 takes a while to run in when you put it in the gearbox and i noticed that its highly effective only warmed up properly but like you, i did experienced some crunching when cold. when i added the G70, it became a whole lot smoother regardless of hot AND cold.
dun you feel your arms muscles tightening up everytime you do the filler and drain plug?? :)
i used the redline stuff in my diff instead. :)
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-649343
Sorry GenesisR32, I disagree. Nulon G70 is the biggest load of crap I have ever put in my gearbox. The shit is TOO slippery. My synchros started behaving in ways that resembled a slipping clutch.
I too had Shell Synthetic 75w90, which I feel comes along side the Nulon additive as being the crapiest gearbox oil on the market. As soon as I changed the oil to Shell, the shift from 1st to 2nd was hell worse. I then added the Nulon additive, the shift was still crappy and I started having synchro problems. I drained the crap (Which now looked like cows milk thanks to the Nulon additive) and replaced it with VMX80, bled the clutch...Perfecto! (well nearly) The 1st to 2nd change is significantly smoother, even in the cold. Oh and so far, no more synchro problems...touch wood! The stupid thing is that the money that I have spent so far in this little episode, I could have used RedLine Shockproof for the same money...oh well...you live and learn.
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-655395
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
