I recently changed my gearbox oil (manual) for some synthetic shell oil (75w90). the box is a lot worse to use now. i can't change into 2nd properly when cold (grinding noises) and every gear is a bit 'notchy', sometimes even when warm.
now i read in some thread that when changing from mineral oil to synthetic oil in the gearbox, sticky deposits can be formed on the gears which make the gearbox hard to use. i think this is my problem.
I was considering putting half a bottle of the engine flush stuff into the gearbox before draining it to see if that helped...is this safe to do? or is there a more conventional method of flushing the gearbox?
or am i completely wrong and something is wrong with my clutch (ie not fully disengaging)?
thanks
Greg
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/
Hey greg, maybe coz the oil grade is 75-90? its slightly thicker than the old stuff u had in there? I wouldn't put any of that engine oil flush into ur gearbox, dunno if it does any damage or not but i don't think any ones tried it before. not too sure what kinda crap is in that flush fluid.
are you changing the fluid urself? or taking it to mechanic? lol, coz i need to change mine.
I think that you should drive the car for a few more k's, and then after that change the oil again with that synthetic stuff.
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-648384
hmm the owners manual say to use 75w90...but i get what your saying, an older/worn gearbox needs thicker oil. changing fluid myself. its easy to to do, GenesisR32 posted a great thread DIY thread, its in the FAQ section :D or i can show ya if you want. thanks denny :)
try using Nulon G70 instead. its great stuff! i had the VMX80 in mine but felt alot smoother with the G70 in it 3 weeks later.
if that fails, then do the flush but i wouldn't recommend it though.
yeah i put a tube of G70 in...it made a bit of difference but its still really crunchy when cold. i might try this VMX80, everyone seems to speak highly of it. if that doesn't work then its redline time. if that fails then gearbox rebuild time lol :D thanks mate :D
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-649232
Vmx80 + G70 = :D
redline oil = :D:thumbsup::D but expensive
the VMX80 takes a while to run in when you put it in the gearbox and i noticed that its highly effective only warmed up properly but like you, i did experienced some crunching when cold. when i added the G70, it became a whole lot smoother regardless of hot AND cold.
dun you feel your arms muscles tightening up everytime you do the filler and drain plug?? :)
i used the redline stuff in my diff instead. :)
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-649343
Sorry GenesisR32, I disagree. Nulon G70 is the biggest load of crap I have ever put in my gearbox. The shit is TOO slippery. My synchros started behaving in ways that resembled a slipping clutch.
I too had Shell Synthetic 75w90, which I feel comes along side the Nulon additive as being the crapiest gearbox oil on the market. As soon as I changed the oil to Shell, the shift from 1st to 2nd was hell worse. I then added the Nulon additive, the shift was still crappy and I started having synchro problems. I drained the crap (Which now looked like cows milk thanks to the Nulon additive) and replaced it with VMX80, bled the clutch...Perfecto! (well nearly) The 1st to 2nd change is significantly smoother, even in the cold. Oh and so far, no more synchro problems...touch wood! The stupid thing is that the money that I have spent so far in this little episode, I could have used RedLine Shockproof for the same money...oh well...you live and learn.
https://www.sau.com.au/forums/topic/32332-flushing-gearbox/#findComment-655395
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
