Hey,
Needed to replace my engine fan due to larger radiator.
Went down the thermo-fan path and now need a controller!
I am after a thermo fan controller which reads water temp sensor (better to get another water temp sensor), can define a turn-on temperature (85degrees) and turns off when reaches another temperature (80degrees)
and turns on constantly when AC is on.
What is the best option to do this?
I have found;
http://www.spalusa.com/store/main.aspx?p=i...item=FAN-PWM-V3 but they want $160usd for it O_o
Thanks for the help
https://www.sau.com.au/forums/topic/323396-thermo-fan-controller/
Drift have a pretty nice looking fan controller & at a very reasonable price...
Haven't used one myself but have heard good things about them. Check it out on their website.
As for the a/c side of things I think you're on the right track. May need a 5-pin relay with two switch points, one for fan controller, one for a/c...
Cant find an instruction manual for it. The site doesnt say much about its functions which is a pain.
i have a hks fan controller, comes with loom etc, it gives in-car temp reading etc, never used, u just need to download the user manual and ur good to go
exactly like this
http://www.frsport.com/HKS-Universal-Elect...ller_p_875.html
120 bucks delivered anywhere in aus u may be :)
exactly like this
Hey,
Thanks for that, let me do some reading up on it to see if it can do what I am after.
Ill try and find a user manual.
Cheers
Thanks for the links Trent.
Cant find user manual for the Drift controller so unsure how it exactly works. Im leaning towards the Spal thermo controller which can control two fans independently and loads them up gradually from 50% to 100% if temperature increases. Stops two thermos turning on at 100% and draining my car of electricity haha.
Looking into fitting an AU thermo shroud as many have done in the past. If it doesnt fit, ill go down the path of your flex-a-lite low profiles.
Oh how i wish you still did mechanical work ;)
on another note (if you see this reply);
had to replace the gtr injectors 440cc with 550cc due to leaks!. Is there a way I can limp the car down to your place for a tune?
Cheers
sounds like an easy job for a small microcontroller and a relay/thyristor... could even run it on PWM using a thyristor to keep a more constant temp.
haha well you seem to know whats going on. Make one up and earn some quick cash :(
Maybe i should. wonder if anyone else would want one.
The first one would be a very rough prototype, if i was to make one. Not too pretty to look at...
I'll have a look at water temp sensors, do ya know where the stock one is located?
this is where it is for the r32, not sure on any other model skyline
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
