G'Day all,
It has been awhile since we ran the SAUWA Karting event.
So I have booked the event for Saturday the 31st July at 1900 (7PM) Race Start
Find the Details below.
SAUWA GO-KART Endurance Race
What: 1 Hour Go Kart Endurance Race
When: Sat 31st July 2010 . 1800 Arrival and Race Suit Fitting 1830 for drivers briefing
Where: Wanneroo International Kart Track (Wattle Road, Wanneroo)
How Much: $220 Per Kart ($110 per Driver)
Guys / Girls,
Following a couple of successful Karting events, Brad and I have decided to run another SAUWA Karting event at the Wanneroo International Karting Track. (NOT WANNEROO RACE WAY)
It will be a teams event with a minimum of 2 people per team, with a maximum of 15 teams, so spots will be limited. But please feel free to come out and be a spectator and slag and generally have a good time at the drivers expense.
The race will be a Le Mans start, and then into an hour (1) endurance race.
Teams will require a driver change through out the event. The event is about seeing who completes the most laps over the hour. So in order to finish first, first you must finish.
These karts are the twin engine Pro-Karts and not your ordinary hire karts, Top Speed is close to 100KMH, and I think Mike and I managed a 96.8 KMH trap speed. So we are looking for keen drivers that are interested in a bit of competition as well as a social fun day out
Team numbers will be limited to 15, however as many drivers as you want per team. This will also have an effect on your driving time as well if you have more than 2 drivers.
Teams will be competing not only for forum bragging rights, but Trophies that will be presented at completion of the race by our Brad and I.
For 1st (Mike & Bard) 2nd & 3rd.
There is a perpetual trophy up for grabs for the winners.
Paul & Tom are our current champions.
Now the serious bits!!
Firstly each team will need to place a credit card down on the day of racing to cover their Kart in case of damages. Now I know that this sounds off putting, but seeing as these are the Pro-Karts it is the only way around of driving them without having a CAMs kart licence.
(No clean, smooth driver has ever had any damage)
Bring your own full faced helmet if you want, (they do have helmets available to borrow )
Long shirt / t-shirt and pants as well as closed in shoes (sneakers) is a must.
For those of you that were there last event, you will agree it was a great race with not only some super competition and some extremely funny moments.
Well, Team Ram Rod is ready to come out and revenge its title loss of fast Kart team in SAUWA.
Money will need to be paid to Brad via the SAUWA Event Bank Details which will be handed out once you have confirmed entry via PM.
Cheers
Mike
Teams:
1) Team RamRod
2) Team Topaz
3) Patty & Pocket Rocket
4) Team Green Wang Pump Racing Scott & Maka
5) Team Chop Chop
6) Team Green Wang Pump Racing 2 Jean - Cristoph & Sime
7) Team Green Wang Pump Racing 3 Ben & Sam
8) Team Steel
9) Team Steel 2
10)Team Wog-Riderz
11) Patty Team 2
12)
13)
  • Replies 85
Haven't seen Tom in ages, hope hes still around to help defend our title. I also haven't seen the Trophy we won ever since I gave it back to Mike for engraving :sick:
Didn't he pretty much win it by hogging the kart? :action-smiley-069:
I linger...
I also haven't seen the Trophy we won ever since I gave it back to Mike for engraving :(
ditto...
Also, I belive we were Team From Behind.... but it's not fitting any more. Maybe "Team Tom" or "Team clearly consist 67% of Tom"
Edited by Topaz
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
    • Yuh, but that one is NLA. There might be an equivalent, but I haven't looked.
    • If you hadn't bought a stand alone one already, nismo make a bolt on adjustable FPR https://www.efisolutions.com.au/nismo-fuel-pressure-regulator-sr-rb-s13-180sx-r32
    • I know and understand they are principally the same. They both cause lock under decel, but the 1.5 nomenclature implies "half" or less locking force, or it allows for more slip or a speed differential between both wheels. Right now the driving manners with the 2 way is pretty rough on transient to full off throttle in the backroads. In other words letting off the throttle too rough is not forgiving, great for drifting, tougher for controlled grip driving.      Yeah, I have watched that video a couple times, I am more so just looking for the confirmation that both part numbers offer the same ramp architecture and are just different settings from the factory.     38420-RSS15-B5  38420-RSS20-B5
