Missfire Boost@4500-5500 RPM - The Answer! (for me at least!)
hey guys i just got my new exhaust system on today, and my car has been missing since! why would it do it after i get the exhaust on? i have a 3inch split stainless dump, gutted cat, to 3inch stainless kakimoto exhaust. any ideas, i have just had my 100k service, it only misses when it hits 2nd stage boost at 7psi, after 4 1/2 rpm ?? ideas would be awsome
My R33 has a similar exhaust setup and was misfiring similar to yours, I tried taking the coils out, having a look at them and cleaning them up with wd40 however that was obviously not enough, as after a week of OK operation it started running like crap again. I just put Spitfire coils in today, ordered from perfectrun for bout 465 all up, and it is running very smooth now.
well i am stoked! wrapped the bastard up and she runs perfect! its amazing how such a TINY hairline crack can cause it to run so bad!
thanks nightman, if not for this thread i wouldnt have my car running so soon!
Had my gtst R33 S2 (stock) for 2 years and first got this problem tonight dragin a VT v8 commodore home ffrom work, we both put our foots down and I just got stuttering from the engine at 4000rpm, hope its the same problem as the rest of u, so its an easy fix.
i had the same problem a while back and a set of iridium plugs fixed the problem perfectly, just got a front mount and exhaust installed and its back, possibly even worse than b4. Does anyone think it could be the fuel filter or fuel pump?
JUTSTAR: dont forget to gapp them at .8mm, i get splitfires this week hopefully by wednesday, dont u worry ill be posting if it fixes the problem
covered my coils in selleys industrial strength silicon, left them overnight and problem solvered, havent had a single missfire since. Got a whole new problem now.
the boosting feels really flat now, it sounds like its boosting and the guage(stock one) shows that the boost is increasing at 4.5rpm but the car doesnt seem to be picking up quick enough. Also at night when it gets cold, the boost almost gets up to the +7 on the stock guage which cant be good. i got fmic, turbo-back exhaust, stock ecu, no boost controller. Im going to take it in 4 a tune soon, hopefully they can sort it out.
hi to everyone!
I've expiriencing the same problem on my R32 GT-R, engine missfire after 4000rpm ander full load(boost 0.8 bar) and engine cut off after some time if I keep running . But I can't solve this problem. I've already tryed to replace ign coil from 3 cars and they was runnig smoofly. I found that where was problem with wiring jaker of the ign coils, I removed jakers in conect wiring directly and sealed with silicone,
esterday i sealed ign coils
like you did, and engine start working well but only if I run on under 1/2 throthle. In other words main problem still remained.
before any work on this problem i found that #3,#4,#6 cyl were not working properly. and even after exchanging coils 3 times they not worked. after fixing connection jaker of ign coils -- #3 and #6 working OK, but #4 NOT
spark plugs - set of new greddy 8 plugs (gap 1.1)
power transistor - was replaced
new fuel pump
injector were cheked and they are OK
and now i want to ask you
what else can cause missfiring on RB26DETT?
Well, looks like i've described my problem and now I'm waiting of your advises on how to make my godzilla run like mad!
and please excuse me for any mistakes in english :nyaanyaa: it's not my native language :thumbsup:
I'm from Russia
Far East. Sakhalin Island (near to Japan)
Edited by voodoogtr
Confusing!
All this tells me, is that no-one actually knows how to "fix" the problem. Some have been successful, but others have found how to just mask the problem.
My mechanic is absolutely stumped. I am pissing him off taking my car in every few days when the 'Check Engine' light comes on, and I'm getting impatient.
The car is under a mechanical warranty, which covers faulty parts, but the mechanic cant find what is faulty. So far, two coils have been replaced, and all the others have been extensively tested (but not in the car - how does that work?) and the plugs have been replaced.
I get the Check Engine light come on intermittently, and sometimes the car will idle roughly, like its dropped a cylinder.
WTF is going on with these cars? I thought Nissans were reliable!
Where do I go next?
A 'For Sale' sign!?
Edited by BlueStagea
They check the coils using a megameter (or similar name), checks the resistance of the coil which tells em if its fu@#ed.
Thanks.
My mechanic had checked them and was confident enough to need two replaced, but the warranty co. wanted them checked by their company, so they were shipped off without the car.
I kind of expected that they wouldnt find any fault with the rest of them, and they didnt. Not sure if its because they are working for the warranty company or if they are too hard to test out of the car.
Replace all the coils with splitfires and get new plugs @ 0.8mm
Next step is to make sure the car isn't running overly rich and this means you need an even better spark to properly ignite the mixture. Ie get it remaped (or aftermarket management) and make sure your sensors are all functioning correctly. If you can't afford this put the stock exhaust back on so run stock boost, this will stop it running it so rich also.
A combination of all 3 of these will fix your misfire providing it is spark related.
They were when they came out of the factory 20 years ago, now they are getting old and parts start failing.
Edited by Rolls
The car is only 7 years old and only at 75000 k's. Plugs are new, exhaust is standard, car is non-turbo so boost wont be an issue. Running on 98 (BP Ultimate). Warranty wont replace parts unlesss found faulty! I'm sure my mechanic will love me telling them what to do, but you guys have experienced this before, so I'm open to ideas.
Cheers
I've already tried install the set of NEW SPLITFIRE'S but it's not helped :nyaanyaa:
At last I'm thinkig of problem in main wiring of engine. Today will try to find out any cuted wires from ECU to engine. My friend got problem like mine and he found some wires were cuted in main wiring!!! Looks like Nissan makes their cars from some junk or shit!
I don't know exactly but it seem to be like this!
Your english is great! Its right to the point. I am starting to think the same way!
Very frustrating.
I am holding off getting Splitfires.
I've already tried install the set of NEW SPLITFIRE'S but it's not helped :D
same problem...threw in a set of splitfires sat & prob went away over weekend but now its back but only sometimes & notice worse when cold...i have ngk iridium's heat range 6 gapped at 0.8mm splitfires & running 8.5psi with r34 SMIC & pod...everything else is std...what could it be? afm? o2 sensor? i was thinking maybe try going back to heat range 5 plugs as before i swapped to the iridiums it was fine?
any thoughts?
I've already tested my O2 sensors and AFM's and they work perfectly! I've tried different gap on my Apexi 8 plugs(0.8 and 1.0), it's not matter for me at all!
If anybody with same problem could test main wiring to find out any crack there it will be great!
As for me I dont know any special trained mechanic to do this for me fo cheap so I'll remove main wiring and check it by myself for free. And of couse I'll inform you 'bout my progress .
Well ... the weather outside is weird so I've desided not work with my car but find out any solutions to described problem.
1. I found that Crank Angle Sensor replacement helped to solve problem. will replace with one from working engine.
2. Also I suppose it might be problem with Intake Air Temp sensor failure, because after short run engine heats up and problems occours from 1500rpm, but on such low rmps it much harder to hear.
3. I also planing to check every relay , maybe something wrong there.
4. And at last main engine wiring harness...check for any cracks
As I suppose my problem not actually missfiring but "rich & retard" causing missfire.
Or possible too lean ..... but I don't know how to find out am i runing rich or lean.
Any thoughts or suggestions ?
Well :P I've found what was wrong with my car!!!!
It was TPS , but it was working only for percentage of opening throttle and not working idle switch. This caused ecu to inproper fuel and timing operation!!!! And there were no eror codes on ecu.
And seems to me I also in need of new splitfires. Because engine work not so smooth on high load of boost.
Good luck you friends to find out yours solutions.
Edited by voodoogtr
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
