not sure of the exact model my A31 is but its one down from the turbo one, its a 1991 facelift 1, RB20DE with LSD and HICAS,
Im wanting to change this to RB20DET, will this conversion require me to upgrade the brakes, even though mine are the same as the turbo version?
depends where you're from man
i want to say no but i'm not your government...
i didn't change the brakes myself when i converted... i probably should have but i didn't.. not cos it doesn't slow down i just ... wouldn't have minded bigger brakes haha - i'm from WA
i don't imagine you would need bigger brakes though
Dan_J is having this problem.
Nissan part numbers claim that the Ceffy brakes are ALL the same, turbo, non turbo, etc...which are variant to the SR20DET brakes.
Dorigecko has a registered RB25DET Cefiro, with stock Ceffy brakes, because they're "turbo model brakes" the engineer signed it off.
Personally, I think the stock single pot brakes suck the biggest, gayest balls imaginable....4 piston brakes for the win.....no really...they pull up WAY better. They'll be more lenient when it comes to registration if they can see you've gone the extra distance with brakes.
Not only is it registered, but it's passed pits with the standard brakes. Three times. Mine pull up just fine EVEN WITH MY FOUR STUDS OF AWESOME.
Ehem. The only problem I see is that the rear discs are a pain in the balls, because no other car that I've found uses the same discs as the ceffy. Definately not S13 because it's drum in disc on ceffy, hydro/mech clamp for the silvias and skylines.
A brake upgrade is always a good thing, so I say do it aswell. If I had the money to spare, I definitely would too. FFS Nic is doing it on his RB20E ceffy. The only way he's gonna get to use them properly is if he stings it at 180km/h in a school zone with a 10km run up, and needs to stop in 100m because of an 84 year old who looks way too much like a 6 year old child.
And when is that going to happen Nic? When, I ask you?
If their anything like the guys in Darwin just use the jedi mind control, like i did when I got my car registered.
First question 'Whats a CEFINO??'
Second mind blowing statement.
You can't have that!!! -----> points to HICAS under car.
Its HICAS four wheel steer FROM factory (wave hand in front of face) - Inspector ; Ah Ok.
I dought (IMO) that they will realise you have change from 2 pot to 4 pot brakes. Even going 4 stud to 5 stud (correct me if I'm wrong here) Well they wouldn't here as they didn't notice my brake upgrade.
PURE GOLD :blink:
all non turbo ceffy's come with 250mm wide by 22mm thick front rotors similar to the non turbo s13 sr20de
turbo ceffys came with 280mm by 22
if anything upgrade your's to sr20det s13 brakes for cheap
Edited by Dan_J
cheers for the comments guys, Im in qld, doing a brake upgrade is on the cards, depending on weather or not I buy a complete donor car for the conversion, if so i'll go the 5 stud route like I have in the past,
at the moment theres a complete motor/box there if I want it, I may get it if I can get away with the stock brakes,
the fact is the RB20DE is mind numbingly slow, before that I had a 20E one in NZ and that was just awful
toffy, is that the r32 ones? They'd need to be redrilled for 4 stud wouldn't they? I tried with S13 rears without knowing that they were different. Was like.... Where are the vents man. What did these people do with them... But yeah. COMPLETELY different. If you can do 5-stud, go for it. be heaps easier for parts as 32 GTS-T or S13 SR is alot easier to find.
at the moment my rear discs are... well below what they should be. skimmed to within an inch of their life. not happy-making i tell you!
  • 2 years later...
Hey Ive got an s13. The front hubs discs and calipers are from a part cefiro a mate had a few years ago. I need new dics (these are scalloped now) but cant remember what they were off so dont know what I need to get
are the A31 Facelift / non facelift / 20de and 25de the same discs, or does each have a different setup ?
They are on the car so I cant measure right now, but they were much larger than the original s13 ones I had.
Need to get fresh discs so I can get the rb20det certed.
4 Stud.
Strap for cash so please dont go off topic about 5 studs or re drilling etc etc
cheers
Edited by faustini
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
