Hi guys,
just wondering if 18x10 with a 15 offset would be fine for an R33 GTR? Will they rub the guards if the car is lowered a bit?
I had a quick search and most people go either 18x10 with 18 offset or 18x9.5.
Anyone got 15 offest on their cars or any advise?
Thanks.
https://www.sau.com.au/forums/topic/323862-r33-gtr-wheels-question/
Hi guys,
Thanks.
Mine are just flush.. havent lowered it though..
18 x 10.5 +15
It needs a wash lol..
Cheers
Johno
mine are +12 and the fronts do rub a tiny bit on full lock. theres a little knob thing sticking out of the back of the inner guards that it touches. pretty sure you could just flatten it down with some careful hammering.
Hi guys,
Thanks.
It'll fit straight in without rubbing on reasonably low, if more low, the wheels will 'camber' in.
Also depends on tyre size, I've got 275/35/18 on 18x10 +19, I reckon I could whack 10mm spacers and it'll look good on mine.
If you're worried about tyres rubbing on guards, get slighty smaller tyres and roll the guards.
oh also ive got 245/40s on mine so a little stretch for a 10" rim
Hi pete,
your car looks fantastic, so your running 18x10 with a 12 offset and 245 tyres?
So based on that, i should be able to get 15 offset and run 265 tyres which is what i want.
also thanks for all the replys, it really is helpfull.
it really would depend on how low yours sits and how thick a tyre you choose too. if yours sits as low as mine (which isnt overly low) then you may encounter the same issue as me. having said that it doesnt bother me at all.
heres a reference for how mine sits at the front, have since raised the rears 30mm
  • 7 months later...
hi guys,
bit of an old post but ive just sold my wheels and am looking for a new set. Ive come across a set of 19x10.5 +22 volks which im tempted in getting. Any thoughts on 19's on a R33 GTR? Also the offset seems a bit higher than what most people run but it looks like the wheels fill the guards nicely.
Hey Peter,
You won't have problems with that size and offset, as long as your not running super hektic low....
You may get a slight rub on full lock when the car is on an uneven surface but wouldn't worry about it too much. Try to keep the tyre width under 285, it will reduce the rubbing also.
As far as the tyres rubbing whilst driving you won't have a problem, again as long as the car is not lowered too much....
Cheers
18 x 10.5 +15
Cheers
Johno
What size tyres are they? I know for a fact 18x9.5 with 285/30/18 tyres will scrub when doing a u turn/ full lock right turn. This is only the case if you lower the car. I'm running super street at the lowest when it was scrubbing.
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
