Hi guys,
just wondering if 18x10 with a 15 offset would be fine for an R33 GTR? Will they rub the guards if the car is lowered a bit?
I had a quick search and most people go either 18x10 with 18 offset or 18x9.5.
Anyone got 15 offest on their cars or any advise?
Thanks.
https://www.sau.com.au/forums/topic/323862-r33-gtr-wheels-question/
Hi guys,
Thanks.
Mine are just flush.. havent lowered it though..
18 x 10.5 +15
It needs a wash lol..
Cheers
Johno
mine are +12 and the fronts do rub a tiny bit on full lock. theres a little knob thing sticking out of the back of the inner guards that it touches. pretty sure you could just flatten it down with some careful hammering.
Hi guys,
Thanks.
It'll fit straight in without rubbing on reasonably low, if more low, the wheels will 'camber' in.
Also depends on tyre size, I've got 275/35/18 on 18x10 +19, I reckon I could whack 10mm spacers and it'll look good on mine.
If you're worried about tyres rubbing on guards, get slighty smaller tyres and roll the guards.
oh also ive got 245/40s on mine so a little stretch for a 10" rim
Hi pete,
your car looks fantastic, so your running 18x10 with a 12 offset and 245 tyres?
So based on that, i should be able to get 15 offset and run 265 tyres which is what i want.
also thanks for all the replys, it really is helpfull.
it really would depend on how low yours sits and how thick a tyre you choose too. if yours sits as low as mine (which isnt overly low) then you may encounter the same issue as me. having said that it doesnt bother me at all.
heres a reference for how mine sits at the front, have since raised the rears 30mm
  • 7 months later...
hi guys,
bit of an old post but ive just sold my wheels and am looking for a new set. Ive come across a set of 19x10.5 +22 volks which im tempted in getting. Any thoughts on 19's on a R33 GTR? Also the offset seems a bit higher than what most people run but it looks like the wheels fill the guards nicely.
Hey Peter,
You won't have problems with that size and offset, as long as your not running super hektic low....
You may get a slight rub on full lock when the car is on an uneven surface but wouldn't worry about it too much. Try to keep the tyre width under 285, it will reduce the rubbing also.
As far as the tyres rubbing whilst driving you won't have a problem, again as long as the car is not lowered too much....
Cheers
18 x 10.5 +15
Cheers
Johno
What size tyres are they? I know for a fact 18x9.5 with 285/30/18 tyres will scrub when doing a u turn/ full lock right turn. This is only the case if you lower the car. I'm running super street at the lowest when it was scrubbing.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
