Hi all was supposed to get my pfc tuned today but found out it was not really working.
according to Paul @ chasers he was able to communicate with the pfc
the problem however, was that the voltage coming out from the pfc (to cranksensor etc.) was too low (way below 12v)
the car wont start with the pfc connected and so they checked the wires and stuff everything seemed to be good
and so they swapped the stock ecu back on and started the car without any problems
so does anyone no where shuld i go?
https://www.sau.com.au/forums/topic/324074-places-that-repair-pfc/
check in the fuse panel on ECR33
drivers side in the cabin
look for ENGINE 10 AMP fuse
check if its blown, if so reclace it
i forget which one is ENGINE 10amp
so check them all
or find a diagram of it my site
paulr33.com
yeh what paul said is correct, and most likely there is nothing wrong with your pfc...
i'm gonna take a stab and say you had a z32 or similar installed recently?... if so theres a good chance the signal wire shorted to ground causing one of the 10A engine control fuses under the drivers side dash to blow... this will give you approx 6-8V output instead of 12V and cause relays to click and the car not to start on the PFC .... however for some strange reason the problem does not affect the standard computer!
so check all the engine control 10A fuses under the dash on the drivers side!
good to hear all sorted
yeah its something thats got me gobsmacked
and we've seen it before, the illusive missing 10amp fuse
i dont get
how ECR33 with standard ECU runs fine and no problems for 10+ years
go and install the PowerFC and it goes spazzo, only to find a MISSING 10amp FUSE
i mean, i get it if was blown right, but a MISSING fuse - that makes no sense?
if its part of the 10AMP engine control, how can it be missing and work with the stock ecu?
why does the powerfc need it? what circuit is broken by this fuse MISSING ????
it make ZERO sense
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
