Got my GTR inspected for NSW rego this morning (pink slip) and while I was there the guy told me the following;
Engineers certs are now only valid for 3 months from the date of issue (and that AKZ - John, is no longer certified!)
and that if an import like ours is taken off the road for longer than 3 months after the expiration of rego, then they will NOT allow them to be re-registererd... this is where a blue slip is normally required (I had 1 day LOL), but apparently they won't allow!?!?!.
anyone heard this?
needless to say, I passed the inspection without a drama off to wakie soon :wacko:
Certainly is two separate jurisdictions.
The similarities are that ACT often adopts changes first implemented in NSW (weight rules anyone?), as well as accepting signatory engineers from other jurisdictions.
Surely the 3month expiry for an engineer's cert refers to the time from when the engineer signs off on it and when the car fronts up to the pits/has the cert number amended to rego sticker. If thats the case then fair enough I reckon. Not being able to re-register after lapsing for 3months is pretty serious though!
The inspector was probably referring to the fact that the engineering cert is only valid if the vehicle is registered within 3 months of issue.
Says this on the form:
This certificate must be presented to the RTA within three months of the date of issue if
the vehicle is to be registered. The RTA may not accept a certificate if it is presented more
than three months after its date of issue.
Sample of the form here:
http://www.rta.nsw.gov.au/registration/dow...3march_2010.pdf
Of course anything could happen when they replace the existing vehicle standards with VSCCS sometime this year.
all the more reason not to bother paying for an engineers certificate.
ACT is great you just keep paying and they think your car is still on the road. no need to go to dickson as long as you dont let it lapse for more than 11 months 30 days 23 hours and 59 minutes.
Shhhhh, we're hoping they don't notice.
I seriously doubt this would be inacted given almost every car on the road is imported from somewhere or another. They would have to define 'Import'.
no, I think this refers to low volume imports such as ours. not the mainstream like MB, BMW, VW etc...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
