Ok, most of you guys are on Prestige Motorsports email list .. if not this is a direct copy. Thanks Geoff!
Here is some SERIOUS NEWS for anyone planning to import a 15 year old vehicle, which will put all recent rumours to rest.
DOTARS are planning to change the 15 year rule as of 1 January 2005. A "Regulation Impact Statement" is being prepared for consideration, which is part of the process followed by the Government prior to changing a regulation. They are currently seeking comments from a range of stakeholders on their proposed changes to the 15 year rule for importing vehicles to Australia.
The following three options are being considered:
Option 1 -- Make no changes to the current arrangements, ie. continue to allow unrestricted importation of vehicles 15 or more years old.
Option 2 -- From 1 January 2005, allow only vehicles manufactured prior to 1 January 1989, to be imported without restriction, ie. no more 1989+ models.
Option 3 -- From 1 January 2005, allow only vehicles 30 or more years old to be imported without restriction, ie. a 30 year rule.
Grounds for the change
In broad terms, DOTARS are citing the following two reasons for the proposed change:
1) NUMBERS -- The trends in importing 15 years or older vehicles (in particular 2003 saw more than double the number imported in 2002), see figures below per year:
1998 3,565 vehicles
1999 3,763
2000 3,941
2001 3,848
2002 5,703
2003 12,291
Hence the concern. DOTARS have stated that left unchecked, these numbers are very likely to exceed the number of vehicles being imported under SEVS. This is obviously the driving force for changing the regulation.
2) EMISSIONS, PERFORMANCE and SAFETY -- 15 years and older vehicles are not required to meet current emissions and safety requirements. Whether valid or not, DOTARS are arguing that allowing the continued import of older vehicles under current arrangements will be detrimental to the average age as well as emissions and safety standards of the Australian vehicle fleet.
On the surface this appears a valid argument, however if unable to import, in reality the people intending to import these vehicles would simply spend their budget on local alternatives. On the whole these local vehicles in the same price range are less safe and efficient than the import alternative, simply based on the types of imports targetted (prestige and performance cars) versus what is available locally for the same price (generally old fuel guzzling and rusty clunkers). We all know the types of cars that can be accessed from Japan and what great value they represent. Almost all are fuel injected and many are prestige vehicles worth more than $100,000 when sold new. After all, if local vehicles were as good for the same money, no one would bother importing would they.
Thinking logically, the only impact we can see of continued import of 15 years and older vehicles as the rule currently stands is an increased rate of depreciation for local vehicles in the same price range as the imported vehicles, ie. $7,000 to $15,000. Thinking further ahead, these local vehicles would then drop down into the price range of those who would otherwise not be unable to own a vehicle, or those who would otherwise only be able to afford a less safe and less efficient vehicle (students are a prime example). So overall, allowing the rule to continue unchanged should actually improve the average safety and emissions for the Aust. vehicle fleet by pushing the old clunkers out though the bottom of the market.
Our opinion on what will happen
We feel that nothing short of a HUGE public outcry will have any impact on the plans to change the 15 year rule. It is EXTREMELY UNLIKELY that the rule will remain unchanged (Option 1) -- after all, if DOTARS thought everything was OK as it was now then they would not be embarking on this process would they. The fact is, from the DOTARS perspective they have to do something to slow the number of imports, so Option 1 is really not up for consideration at all.
That leaves only Option 2 and Option 3 to choose from. While going to a 30 year old rule would be an attractive and immediately satisfying outcome for DOTARS, we suspect they will avoid the sledgehammer approach and will prefer Option 2, which limits import to vehicles made earlier than 1 January 1989. This will have the effect of reducing numbers over time as vehicles of this age become harder to find, and will cushion the impact on Australian businesses that rely solely on 15 year old vehicles. Therefore, the outcry from the public and from the industry will be softened to a point where there will be no solid opposition. Most importantly for DOTARS, this approach would also stop the import of all the new and attractive 1989 models after allowing only a small taste of them in 2004.
When should I buy a 1989 model ?
The short and obvious answer is AS SOON AS POSSIBLE, before the rule changes and / or an announcement is made.
The proposed 1 January 2005 change sets the timeframe. Working back from that, DOTARS need to announce the change they decide to adopt with enough time to allow a transitional phase so that no one is seriously caught out (like their last announcement on 2nd September). This period is likely to be 3 to 6 months, so between mid 2004 and Jan 2005. The DOTARS process of considering the changes, deciding, then passing them may take them several months. At this time they are likely to make an announcement of the change to the regulation. We would expect something to be announced perhaps by the middle of this year, possibly earlier if they can manage it. How they will phrase the announcement we do not know, however we suspect that they will lean towards doing their best to limit the number of vehicles being bought before the regulation changes on 1 January 2005.
DOTARS have clearly recognized that all the new 1989 model shapes represent the biggest threat to import numbers. Even if Option 2 is chosen, they are likely to put a stop to the import of any 1989 model vehicles from the date of the announcement just like their recent announcement. Proof of purchase (funds transfer receipt) prior to the announcement date would probably be required for an exemption where the vehicle was only eligible for import late in 2004.
So as we see it, the next 3 to 6 months should be viewed as your LAST CHANCE if you wish to guarantee the import of a 1989 model under the 15 year rule.
Based on the above reasoning, we recommend that customers who want to import a 1989 model under the 15 year rule should GET IN AS EARLY AS POSSIBLE. Just as those who bought 1989 models prior to 2nd Sept. 2003 were rewarded by being allowed to import their vehicles in Jan 2004, it is natural to assume that those who buy now will also be rewarded for their forward planning when the rule changes this year. It is much better to buy now and factor in up to 11 months storage for a vehicle in Japan prior to shipping, than to miss out altogether.
Bear in mind that many 1989 models are not eligible for import under SEVS. So after the rule changes you will be unable to import them AT ALL. Examples are the MX-5, MR-2, Celsior, 300ZX 2+2, Porsche, Corvette, Galant, Supra (MA70 / GA70), Legacy, RX-7 (S4 / S5) etc., basically all the good options and you can certainly kiss cheap R32 GTR's goodbye with your alternative under SEVS being $5,500 plus tyres for compliance. These models are set to disappear from our import menu for good with the proposed changes.
Payment for 1989 Models to be imported in 2004
Note that only the FOB cost of the vehicle and our service fee need to be paid to commence the process, then the remainder (shipping, import duties, GST etc.) once the vehicle arrives in Australia. This means that you can secure 1989 models in advance with a payment of usually between 40% to 50% of the total vehicle cost, with the remainder not due until after arrival.
Have your say
We would encourage anyone that has an interest in this issue to have their say now while they still have an opportunity. It would be a very optimistic person to see any outcome other than either Option 2 or 3 being chosen, neither of which will all leave the new 1989+ models that we are now looking forward to, available for import. So don't save your opinions until after it's too late to have an impact and the 1989+ models are out of reach -- get organised now, mount a solid case and sound arguments for keeping the rule as it is and get these in to DOTARS on the proper form (see below).
We would strongly suggest that all comments be restricted to rational arguments based on the options proposed and the reasoning behind them. This is the only response that will help the cause. In particular, mad raving about how it just shouldn't happen and how good things are now without any valid reasons is likely to have a negative impact rather than a positive one, and will divert attention away from the very valid arguments that should be mounted against the proposed changes.
In addition to well reasoned arguments for Option 1, it would be worth focussing on options that you believe would be better than those proposed by DOTARS, but bear in mind that these would have to have some significant advantages for DOTARS over the current options that have been put forward to even receive cursory consideration, ie. ease, cost, political advantages.
Who to Contact
Ross Docherty
Vehicle Safety Standards
Department of Transport and Regional Services
GPO Box 594
Canberra ACT 2601
Fax: (02) 6274 7714
E-mail: [email protected]
  • Replies 92
Well... this is quite serious isn't it... I'm kind of torn.
On one hand, it's their stupid fault for introducing SEVS and making it prohibitively hard to import cars through that scheme. So this obviously forces people to go through the 15 year old rule and purchase older vehicles.
On the other hand, I don't want a stupid influx of 15 year old pollution-making machines (which many are)...
They cite that their main concern if the sheer numbers, and environmental impact as the two reasons for the need to change the rules... I might write to them suggesting they loosen the SEVS stranglehold, and limit the importation of cars to ONLY those that are exactly 15 years old by year of manufacture (not month like it is now)...
This has two effects:
1. It will allow more modern cars to be imported into Australia, but at greater cost to a 15 year old model, so lesser numbers will be imported. Also, being more modern cars, they will be subject to emissions standards.
2. By only allowing 15 year old cars and none older to be imported, you filter out a lot of the older pollution-belching cars that would otherwise skip emissions testing.
Firstly I am an import lover....... however im all for the ban of 15yo vehicles.... just cos we dont really need an influx of cheap GTR's for 18yo to be drving around in... secondly i dont want my car to lose its value!
Secondly, with my dad being in the auto industry for over 40 years now I can see their point of view in relation to the 15yr rule and SEVS..... and at the end of the day the big companies make a lot more money for our governments than your private importers... so decisions are always going to be intheir favour.
As an R32 owner, im happy, as will alot of other R32 owners. However Id still like option 2 to be employed so the likes of Ceffies and Supras can still get in the country. Lets have a sensible system.
How about an embargo for a further 5 years on 89 models and then move the limit up slightly. So over time your still letting in the nicer models but not ruining the value of others already in the country complied under SEVS. Say in 2010 you move the limit up to say 94.
Red17
should be interesting to see what happens I feel there is a place for the 15 year rule as it stands . one main reason is the fact that the japanese cars have less milage and more frequent serious inspection than australian cars of the same era.
cheers
It will make people looking at buying an early model R33 probably a bit happier. In about 3 years R33 series 1 will almost be 15 years and prices would probably drop a fair bit if the current system is still in place.
So could be good news for r33 owners.
Why don't they have a compliancing plate style system (minus the harsh SEVS/RAWS compliancing) for 15 year old imports and only allow so many "compliance plates" per year - thus limiting the amount of 15yr imports. Either that, or they've got to cut a little more slack in the SEVS/RAWS scheme as it's getting difficult to import cars.
As an R32 owner all I can say is im happy there doing this. The last thing I need is a bunch of beaten up 89 GTR's coming in and ruining the value of all skylines (whos going to buy an r33/r34 when a dealer sells them an "immaculate" gtr for the same price thats actually an 89 beater?)
But thats just my opinion.
They keep people in jobs and those people pay income tax.
Not to be confused with the companies themselves who's creative accounting and offshore ownership mean they dont actually owe the government any money for tax and in fact that the government must pay them for the pleasure of operating at a financial "loss".
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
