Well not exactly,
However, I've recently bought an R33 GTR, the thing is in brilliant condition however I noticed that the front torque gauge would register a split as soon as I moved, no matter how slow I was taking off.
Didn't know why for some time, then realised that the tyre brands front to rear were different. I did a little measurement and found there to be a small difference in overall diameter from front to back.
Now the rears actually measured smaller than the fronts by virtue of their makes so in effect, the computer is seeing that the rears are slipping as they are having to turn a little faster to travel the same distance. So I'm wondering if anyone here knows if the result would be the same if I put the fronts to the rear and vice-versa which would then have the rears turning slightly slower than the fronts.
Would this still produce the same result of torque split? Does it work in this situation where the fronts and turning faster than the rear???
I'd love to know before actually changing them over. Ta.
https://www.sau.com.au/forums/topic/324277-r33-gtrs-have-too-much-torque/
No, the ATTESSA will behave itself. (and you could have found the answer in any number of threads which deal with this phenomenon)
Well actually no blink_elk, this specific idea has not been addressed, everyone discusses how a difference in general will affect the system, however no one discusses the difference between which way it occurs... ie. front rotating faster or front rotating slower.
But thanks for your response and if you're right, that's very interesting to me.
lol . if i was you i wouldnt be making a piont of it.
everyone always talks about how putting the spare on the back f**ks it up and putting the spare on the front is fine(spare generally being a small space saver)
go read up on attesa and you could have figured it out all by yourself ....
Your guess is correct and 33 & 34 GTR's do pre-load the system. No matter how slow you take off the torque gauge will register a little as soon as you start moving until you're rolling at least 20 km/h (from my experience). Then because your rears are smaller, the computer "thinks" that your rears are spinning and thus will transfer torque to the fronts to try to compensate. If the diameters are out enough will do it all the time - that is what is bad for the transfer case. It will try and engage the 4wd but due to the different diameters will force slippage in the transfer case. Over time this will burn it out - they are VERY expensive to fix so this is a bad idea.
If you have to drive it to the tyre shop, swap the larger tyres to the rear so the rears are spinning slower than fronts. This is a temporary fix but get them sorted out quick.
Cheers guys, I'm taking it that it doesn't happen the other way around (ie. rears moving slower) as some have suggested.
I've put the same brand on the front and it's right, little bit in first at take off and does nothing from then on until it's howling...
Incredibly sensitive system, as the difference between the two was less than 5mm!! And the effect was immense. Fantastic car. Bit like a fussy child who doesn't like wearing different coloured socks.....
Thanks again.
yeah i the allowance before slip is 5 % i think , or might be 2% .
i thought nissan could at least privode a spare the right diameter to not cause this but no .
and also under full power you will see up to 30% to the front even if the rears not spinning
also it will go up to bout 30% under hard braking (like emergency stop with abs ) as it hinders wheel lock up
i dont know if youll A ever get it to do this or B if it shows on the gauge
  • 3 weeks later...
IT WILL NOT MOVE UNTILL THE REAR TIRES BREAK TRACTION
Incorrect.
Strong acceleration will move some load to the front wheels, just not a lot.
ATTESSA will work on corners before you lose traction.
You don't need to be too worried about the front torque gauge not moving all the time, you'll notice the difference mostly on corners / hard acceleration or loss of traction.
Incorrect.
Still not happy with the fact that my auto GTS25t feels like it's got faster pickup though...
Doing a service tomorrow and will look at the air filter, spark plugs and AAC valve.
Incorrect.
Correct. In addition to this, ATTESSA also factors in the speed that you're driving at. You'll notice that cruising at 60 km/h there is some torque going to the front wheels, and you'll notice there's even more when you're cruising at 100 km/h on a freeway.
Edited by ras1983
No mate, ATTESSA was upgraded on the R33 and R34 models and the fronts are much more active than on the R32's.
Have a look at the Autospeed road test, Julian noted this with the R33 that he used for the road test.
I have been in and have driven several R33's and a R34, and they have all displayed this same trait.
The system should be engaging around corners, when accelerating out of them. But when accelerating out of a corner, keep your eyes on the road :(
The passenger can watch the gauge for you...
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
