Im in..
Terry what are the alternative payment methods ?
Hiya Ben, I've PM'd about cheque payment if you don't have VISA or Mastercard (Credit/Debit)
Most happy to do that - Humbla is sending a cheque too.
  • Replies 311
Posted Images
Tickets (with receipts) have now been sent to these postcodes (latest > first)...
2795, 2166, 2095, 5013, 2138, 2232, 2148. :)
It's been fascinating to watch so far, that every person has purchased 'multiples' of cinema tickets eg. 6, 4 or 2.
Needless to say, there will be lots of 'single' purchases along this 'journey'.
The Helpers/Organisers for this "Godzilla Event" are...
Nick aka Black_Widow
Matt aka God_speed
Shehan aka lankanboiiR34
Shanil aka SHANE666
Bobby aka NISMO
Eric aka Pezhead
Sam aka Rocklee
myself
+ Kat aka GTRKat (with the ACT contingent)
Without the above and SAU, nothing & I mean nothing, would get done.
The efficiency of how most of us got the 10th ANNIV of the R34 GT-R in April last year up 'n running within 6 weeks was remarkable!
And nothing on the 10/10/10 will happen unless Attendees like yourselves make this Event a sellout!
So, don't just come to the cruise; buy your tickets NOW @ $15 each (as per Payment options in the 1st Post)
Sorry if I'm just dumb Terry, just making sure, send $30 for two people? :( Very keen to come to this. Big trek, but worth it.
Not dumb! Just $15 for each bum! :blink:
So yes Owen, $30 on Visa or M/C with name + card# + expiry# + phone# + address; to send you the receipt & 2 tickets for entry to cinema.
Above details are to be e-mailed to [email protected]
'Twas good to see you again at the AGM! :P
Yep ill be in for this with the missus........this will be my first SAU cruise. +2
Yes Simon, just send those details of yours please to [email protected]
Enclose Name + VISA or M/C debit/credit card# + expiry# + address + Phone#
...if you will. Cinema Tickets and receipt will be out to you within a couple of days.
This is a great day for the girls too! :blink:
OK David lol
FYI, the aggregate of Postcodes (in reverse order - ie. last > first) where "purchased cinema tickets" and "receipts" have been mailed are...
4210, 2615, 2203, 2795, 2166, 2095, 5013, 2138, 2232, 2148. :P
Not dumb! Just $15 for each bum! :P
'Twas good to see you again at the AGM! :D
Awesome, will do that next Wed/Thur, gotta wait for payday! So if it's filling up fast, I'm screwed :down:
Was good to see everyone at the AGM! :D
Had a look on Google maps, it works out to be around 113km.. But I could be wrong
That's right mate, there's a GoogleMaps link underneath the map in the first post which gives turn-by-turn directions and says the cruise part is 112km, from the start point at Penrith, to The Edge at Katoomba. The distance from Katoomba back home also needs to be considered. But we've already got people coming from interstate, so the distance shouldn't be a barrier!
This is definitely something to look forward to, and we're expecting a great turnout. :D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
