As topic states im trying to sell some gear due to upgrading. All parts were working fine when removed from R33 GTS-T SERIES 1
1: Apexi Power FC with hand controller suits r33 series 1 & 2: $1250
2: Z32 afm with plug: $170
3: Stock Turbo, good condition, only went to 10psi with this: $150
4: rb25 fuel injectors, (can come with rail if needed and injector wiring and o-rings for $150): $100
5: Stock coilpacks RB25det series 1 (fine before removed): $100
6: Standard RB25 exhaust manifold: $20
7: R33 fuel pump: $30
8: Charcoal Canister: $20
9: Top half of intake manifold: $30
10: Intake manifold bottom half (will sell top and bottom for $50): $30
11: Brand new gasket for joining manifold together: $20
12: Turbosmart boost controller 1 way manual tee: $40
13: Apexi pod filter, bolts to standard afm (not sure about the z32 though, never tried): $40
14: Stock blow off valve: $20
15: Stock throttle body (without tps sensor): $30
16: Coil pack harness to ignitor for R33 series 1: $15
17: Front mount cooler piping 2 and a half inch: $80
18: 80mm to Standard size throttle bottle adapter: $30
19: Speco mechanical water temp gauge with sensor: $20
20: Standard boost controller solenoid with connector plug :$30
21: Standard Rotors front(29mm) and rear(17mm) bit of surface rust: $100
free pads with rotors if wanted, fronts not the best, rears are bendix ulimate(pretty much brand new): $20
22: Standear bolt on engine parts i havent listed i should have, just ask, eg: rubber intake hose
Will get pictures if needed but all parts are pretty coming and you should know what they look like
Can email pics straight away, just to lazy to resize them and upload them on here atm.
Pick Up is from North Brisbane, Caboolture.
i think prices are fair but willing to negotiate on some things
I will post if serious about parts, due to no transport atm though only ask if your serious please, i will only charge whatever it costs to send.
not willing to seperate at this stage mate, but if i do i'll let you know.
Power Fc and z32 will sell for $1350 together.
Forgot some things
Standard ECU rb25det SERIES 1 manual: $50
Kicker L7 sub in box: $400 ono
This sub took up the whole boot in the 33 coupe. Sounds awesome. A few scuff marks on the back of the box only on the outside...
sitting on top of 18 inch tyres to give you an idea of the size
Edited by mattis96
Hello, please let me know if your willing to sell the power fc ecu, dont need hand controller. thanks, :D
ill give you a call tonight before qld starts kicking ass or tomorrow? let us know what time suits you as i work night shift and dont my mobi is playing up, so will call you off home phone which is private number what ever time suits you... if buying multiple parts will do cheaper to...
hey mate is the z32 still up for grabs and wat size and condition is it in ? pm me back im in syd if your interested in shippin if the condition is right :D thanks mate
tried calling this morning no answer and no voicemail so couldnt leave a message. had interest but no buyers yet. am negotiable on some things...
Dont know how to edit original post.
PRICE DROP on POWER FC: $1200 Delivered
PRICE DROP on Z32: $160 Delivered
TOGETHER: $1320 Delivered
Edited by mattis96
hey m8 sory about late reply but yes i am still very interested ive just been trying to track down a NAB send me a pm and i will do a deposit at 11:00am wednesday morning
very interested pm me if not already sold
hey buddy, deposit recieved thanks, will send out first thing thursday morning, do you want it express or registered?
update on whats sold.
power fc
front mount piping kit
turbosmart boost controller
standard blow off valve
z32 afm pending payment / collection
coilpacks
power fc
coilpacks
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
