define easy ? if you have all the tools and a hoist its a piece of piss . saying that the jack on the drive way is still fairly easy if you take your time and think about things first
Fitting coilovers yourself is achievable but anyone in your drive way if you have some spanners/socket and a jack. You'll easily get the mfitted in an afternoon taking things nice and easy.
Flat ground! and car stands... The only way, and brick behind wheels, front of car then rear of car, put car up on stands (wheels removed) then use a trolley jack to take the weight of the hub, unbolt everything then throw your coilovers in bolt everything back up using locktight then repeat... easily achievable in an afternoon.
just got back from a pedders saftey check
problems found were
- worn link rods $195 fitted
- sum play in the steering rack POA
- front bump stops $192 fitted
- rear bump stops $192 fitted
- rear shocks fail $992 koni fitted
and to get rear sway bar fitted 95$
am i better getting a BC coilovers? are they easy to fit yourself?
any thoughts
Are the bump stops made out of unobtanium?
by the beard of zeus
$992 for 2 rear shocks
get a bc coilover kit in there asep bru!
stockpile all the parts, invest in 4 jack stands and a half decent trolley jack
install it all yourself or with a mate
then limp round for an alignment
(getting bc coilovers means you wont need the really expensive bump stops either)
I suggested going to a good suspension shop -that excludes Peddars by definition!
You can do all that stuff yourself (do you really need a new steering rack?) or better still with some mates (cost of a tray or two).
I prefer Bilsteins to cheap (adjustable?) coilovers but try a drive in a car with the suspension you a looking to buy and make your mind up that way rather than spend money and wish you hadn't.
who has a family and has bc coilovers?
and what does your family think of the ride?
Yep, a missus and a two year old, I was a bit worried when I fitted them. I have them on the softest setting, when fitted, my missus commented that the ride was so much better than before, much less "boaty" The original gear was pretty soggy. My 2yr old regularly falls asleep whilst driving, so I reckon that say enough.
Which ones are you going to order? I was looking on JustJap and saw there are two different one for S2 RS4
BC Racing Coilover Suspension Kit - Nissan Stagea WGNC34 & Stagea RS Four (Auto Only)
V1 Design VS Series - 30 Level Damper Adjustable - $1199
or
BC Racing Coilover Suspension Kit - Nissan Stagea WGNC34 AWD
BR Type RS Series - 30 Level Damper Adjustable - $1299
Can anyone tell me what is the difference between the two?
or
Taking a more than likely stab in the dark, is the first one for rear wheel drive only?
isn't the manufacturer a seller on here?
if so it'd be best to get them from him
or straight of their website
or ebay (just as cheap i think)
just make sure you say that its an auto awd stagea and you should be fine
I have the BR setup, all I can see that is different is the adjustment collars are a slightly different design, and they're gold, versus red on the VS. I would say the cartridge is the same.
I think on other models, the BR has adjustable pillow ball camber plates as opposed to rubber mounted top plates. This is irrelevant on our vehicles, and a pillowball top mount would be much harsher & more susceptible to wear.
I purchased mine on Ebay from a seller in Unzud for $100 less than Just Jap has as retail, and that was delivered to my door.
or
the BR type has camber tops. i went for the V1's under recommendation from the seller, they said the BR's are a bit of overkill for the stagea and the V1's would be more than up for the occasional track day.
or
now you got me confuse on what to get
i just emailed justjap to recommend
i'll let you guys know which one i will order
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
