Hi Guys,
I am trying to clean up my wheels. The middle part of the wheel cleans up nice with some wheel cleaner. However the dish remains stained. I have tried different wheel cleaners but it seems to be within the metal now. I also tried quickly some metal polish but no luck either.
Any ideas?
Here is a pic, needs to be closer but you get the idea.
Tried "Upper Engine Cleaner" from Subaru?
It could remove all the sh/t that was on my OEM wheels from Japan.
It works if Zymol wheel cleaner doesn't.
When it's all off, you may need to respray the wheels with 'clear'.
Ah ok yup thats the next step if I cant do it pretty easily myself.
After some google searching I found two products, ALUPLUS and ALUBRITE. It is an acid that is supposed to clean aluminium and then polish it really well.
Think I will try that and then resort to a rim repair shop if it doesnt work.
That ALUBRITE is a pretty harsh acid, Ive used it to clean the outside of the head, the cross over pipe and stuff like that.
ALUBRITE will burn your hands if you dont wear gloves its that strong, it will eat the duco as well and anything else that gets in its way... Ive used it in conjunction with a toothbrush to clean all sorts of things... it'll clean brake dust build up off rims, but it will also scar the paint and leave shiny alloy dull, I havnt tried it on powdercoat...
But it should work on the aluminium dish of my rims as long as I dont get it anywhere else?
I will just try a very small part of the dish with a toothbrush to start off with.
Edited by Harey
As mentioned alloy brightener can make shiny alloy dull but if you then polish it you should be ok...
Be careful with the stuff. Wear a mask or don't breathe, & wear gloves. I use it at work to clean transmission cases & it's strong stuff!
You'll know when you breathe it in...
Edited by wlspn
hey... okay here's what you do.
first of all.. this method sounds strange and it will be MOST noticable with bad rims (i mean RIM rims... not "wheels")
go to bunnings
get a very fine steel wool.
no. not that dishwashing crap that you use to get black stuff off pots. this is steel. wool. SIFA make it.
looks like that.
rip a chunk off. big chunk. the bigger the chunk, the more surface area you have to scrub with. the more surface area. the less pressure. less pressure, less chance of scratching. get it?
use either water - or olive oil as a lubricant... i suggest olive oil as it won't ake the steel wool RUST. use a lot of it.
gently rub the steel wool on the wheel. if the stains won't come out, apply a little bit more pressure etc
the basic premise of this is... steel wool is soft as butter. but it is still a METAL. your aluminium / steel rims are a harder metal, and will not "give in" to the steel wool easilly
the steel wool sacrifices itself to clean the metal.
give it a go if you so wish - i imagine that there is a certain element of risk doing this method... but i've done it plenty of times on my wheels which - at one stage were VERY badly corroded.
steel wool is about 8/9 bucks
everyone else take note.
oh and wash the olive oil off the rim using a soap / detergent / shampoo (dah)
  • 1 month later...
i think you need to determine if the dish area is clearcoated from factory - if it is, you will most likely need to remove that before being able to polish it.
Your right on the money here, the dish does have a clear coat.
I started with the steel wool and it wasnt doing much, so I went a bit harder and I could see it take the clear coat off and go down to metal. I have only done this in one small area.
What issues does removing the clear coat raise? Should I remove it or just leave it there and give up.
These guys seem use aircraft stripper to remove the clear coat:
http://forums.corral.net/forums/showthread.php?t=763405
They just say it takes a bit more effort to keep em clean. Its only the dish of my wheels so dont have little nooks and crannys that would be tricky to keep clean.
Would love the rims to have a super shiny dish :happy:
I am leaning towards removing the clear coat.
Edited by Harey
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
