http://feedback.ebay.com.au/ws/eBayISAPI.d...eedbackAsSeller
He has some pretty positive feedback about them, but also only has 33 feedback, so it's possible that they are faked. Maybe message a few of the people that left positive feedback and see if they respond and what they have to say about it.
dude, are you serious?
if you need to ask, its BOGUS
check out the post on ebay
http://cgi.ebay.com.au/HKS-BLACK-UNIVERSAL...=item2c551a8541
now check out the official HKS spec
http://www.hksusa.com/products/more.asp?id=792
the ebay AD is basically the same thing with japlish mistakes in it and grammer errors and the diagrams removed
Ok looking at mine right now, It is either the worlds greatest copy or its genuine!
right down to having HKS cast into the vacume T-pieces
Quality is what you would expect from HKS as-well
So i do belive this might be the bargain of the year for me!
you can plumb these back with an adapter quite easily, i have one of these, no leaks def seems genuine!
Same. Ive had mine for 4yrs. NOTHING has gone wrong.
P.S. Get rid of that homo squeek by removing the tri-fins :down:
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
