Fatz Enters The 2011 Shitbox Rally In R31 Style (sponser Me!)
  • Replies 64
Nice work man - I saw that and would love to do the rally one year.
I should have kept my 31 - it only had 400 000? on it.
looking for some stupid ideas to do to the rally car
ill try anything
hit me with them
Cut springs with angle grinder
Bolt (or pop riveted) on flares made from sheet aluminium from Bunnings
Remove bonnet
Speed holes everywhere!
CAT mud flaps (RM Williams also acceptable)
Truck style clearance lights
At least 2 massive antennae (connection to a CB unit is optional)
Massive driving lights (connection to power is prohibited)
well we have some progress
bidding on this badboy of a f100 truck
http://cgi.ebay.com.au/Bull-Bar-Roll-Bar-F...=item2308546aac
and scored some truck flaps
and did i mention sponser me!
http://www.everydayhero.com.au/von_trapp_family_shaggers
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
