hey all, this is more a "just curious" topic, but i purchased a car (havnt picked it up yet) and the car has a 3.5 inch zorst with a stock turbo, now in the past ive had a 3 inch zorst on the same system and found it enough, but will 3.5 inch be worse for the performance of the car? to me it seems like there wouldnt be enough back pressure.
Anyway, i guess the MAIN question is, how much of a drop in perfomance will there be with this exhaust? should i invest in a 3inch?
stock PSI to BTW
cheers
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/
It will not hinder performance.
EPA issues however are most likely.
sound or pollution?
An exhaust CAN'T be 'to big' UNLESS you are going to give the exhaust 'to Big Al, your mate'.
Otherwise it is 'too big'.
But in this case, it isn't.
:P
i dont get it
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306028
sound or pollution?
i dont get it
Lol. 'to' and 'too' - two (hehe) different words.
The problem will be with volume, but I wouldn't worry about it (unless you get defected).
The size shouldn't make any difference to emissions as long as there is still a cat.
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306048
no i don want to take the cat out, srsly, i dont want the extra 500rwkw from taking the cat out, its just to fast for me, so ill leave it in.
i was under the impression that you need some sort of back pressure, but iono
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306058
I believe the extra 500rwkw will make it too fast for you.
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306088
turbo engines are rather different to natro engines when it comes to exhaust requirements. as has been said, you won't notice any difference between a 3" and 3.5" system. if it was on a NA car, then it would be a totally different story
ok, good thanks! :P
i dont realy care about the size, i just didnt want it to be any worse than a 3 inch, which i beleive is optimal for a stock turbo.
is that all you picked up? lol what about - don, srsly or iono, but its good to see u picked up a missing "o"
cheers mate :angry:
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306102
As far as I'm concerned any of those 'made up' internet slang words mean you are speaking another language.
But mix up your 'to, too, two' or 'you're, your' etc while attempting English and it's just plain slack. :P
But srsly, your exhaust is fine.
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306173
hehe ok cheers mate
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306181
It won't decrease performance, on engines with forced induction the less exhaust restriction the better.
My 33 had a 3.5" system with a stock turbo and very few mods and it was pretty damn loud (didn't have a cat or any mufflers bar the cannon though), did sound mint but.
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306751
Provided you have control of the fueling and timing it shouldn't be a problem , noise and cops aside .
The theory is that the best exhaust is no exhaust behind a turbocharger which obviously isn't going to cut it in a road car .
The turbo rally people like to start out big behind the turbo and step down in stages on the way to the back . What this is said to do is maintain gas speed in the exhaust system as the gas cools and contracts so to speak .
Its a way of having a large volume behind the systems chief restriction , all gasses are channelled and accelerated into the turbine housing , so the red hot gasses have room to expand into . The way to drive the turbine is to have hot gas at speed on one side and a large volume to spread out into on the other side .
As the gas cools it wants to slow down if the exhaust tract is the same all the way to the back , if it slows down too much you can have reversion issues if say the turbo/exhaust manifold/ports/valves/cams are sized to make high rev grunt .
So , the way to keep it moving is to step the tube size down in stages so that the gasses maintain some momentum and velocity .
My old dinosaur Subaru RX Turbo (1.8L 2 valve tiny port flat four GT2554R turbo) has a 3" tube from the turbo to the back of the gearbox and 2 1/2 from there . Its surprisingly quiet but both mufflers are in the 2 1/2 section behind the 3" cat .
It still has its AM radio tech computer and suffers no reversion crap/no pops spits OR drones anywhere .
I suggest that if you have to do something to reduce noise start at the back , its the cheapest easiest way that gives the least restriction in an exhaust system . Car manufacturers having been doing precisely this for some years now .
A .
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5307360
A .
thanks for the info, very helpful, so with the 3.5 system in there with stock dump and front pipe, its not helping it i assume haha, but i will invest in a 3 inch bellmouth for the dump/front.
i dont have an issue with sound at all, its quite quiet actualy...
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5307384
so ive heard
What im wondering will a 3 inch dump/front pipe into 2 3/4 catback be aiight..is there any real point buying a whole system for 1/4 of an inch?
Or will i be captain sloooow.........
the only place you may lose some power is high up in the revs. general driving around and even just reving up to around 5000rpm probably won't make a scrap of difference. anything above that i think you would have to put it on a dyno to see the difference in power. don't think you'd notice the power when driving it. if you were aiming for 250kw+ then it might be worth going 3" though.
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5307439
so if you were after more responsive midrange power the 3.5" exhaust is too large, is that what people are saying?
I was told by a tuner that a 2.5" custom made exhaust would be better than my 3.5" hks, this is what I was told when I told him I wanted to get a tune done for a HKS2835 with supporting mods...
I did say I was after good midrange response, and that I was not interested in ultimate peak power.
I didnt know wheather to trust him or not?
this is on a 33gtst
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5308677
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
