You could ask Streeter or Import Monster to get a rail for you
If it's any help the Bride FG rail in my S14 has a width of ~430mm between mounting points (you can adjust the width, maximum 430mm)
That's plenty big enough for most regular sized seats. The FG rail is available for R34 too, in terms of an 'off the shelf' rail I think it's the best option.
You could look at a Chinese rail like 'powerrail' too but i question the quality.
Not sure what bride rails are like on other cars but the ones I've had are absolute Shit. Paid a fortune for them. Would be better to spend that money on generic rails and get a fabricator to make it mount to your car.
(Depends how much you can get them for)
What problems did you have with them?
Mine seem spot on, really well made and bolt right in, plus they slide too which isn't a bad option to have.
Mine were AU $300 delivered. Made to order by Bride too which is cool.
  • Like 1
The bride's for pulsar is single piece, can be very tough to move and not smooth at all.
Brand new around $350 a seat, from memory
There's lots of different models of Bride seat rails, some are one piece for bottom mount seats or two piece for side mount seats.
Those rails look great! It's interesting to see the difference between the side mount rail you have and the bottom one I ordered, which is a single piece. On the one hand you might think that a single piece is more rigid on side impact but then again when bolted properly to the two piece the seat itself becomes a part of the structure I suppose.
Does yours have a mounting point for the seat belt receptacle?
I hope mine fits and slides ok :) It was $200 posted, second hand. Hopefully it'll arrive tomorrow so I can check things out. Was a hard one to find.
Easier said than done it turns out, I've been trawling the forums to confirm which rails would suit a sedan.
I've tracked down the following Bride rail on sale:
BRIDE bottom mount seat rail type-RO drivers R/H side for NISSAN R34 GTT, W405mm x D260mm/235mm bolt holes
Details off the sticker: Bride Super Seat - Model R34(RWD) - Type RH - Code N105 - Parts list B
> Can anyone confirm if this rail suits an R34 GTT sedan?
I've found two older SAU for sale ads for 4door Bride rails and they had the following details on the (older style) sticker:
Bride - Model R34 - Type RH (T) - Code N105SO - Parts list SN*1
I can't find a clear answer if N105 and N105SO are for coupe and sedan, or whether the N105 is just a newer version of N105SO?!
I got the Bride N105 and I can confirm that it suits an R34 GTT (RWD) sedan. It's good quality, just needs offset plates to suit the Sparco seat.
In hindsight a side mount rail might be better to help go a little lower and allow for tilt adjustment too.
  • 1 month later...
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
