Thanks eric.
Not sure why you think my current radiator is going to blow up? I even got it pressure tested it yesterday and they said its perfect.
I have never had over heating issues either even with that fat 100mm intercooler in the way!
I don't think it will blow up - It's just every track day I got to, I see atleast one or two radiators (non aluminum) give out. More of a safe guard than anything to protect your efforts. Like I said earlier the car is great props.
well she got tuned today and made 398.3hp at all 4 hubs! very happy with it, especially since it was such a hot day today, the midrange has improved alot and the off boost driving is much smoother now, doesnt feel lazy under 3000rpm anymore!
Max torque is now 1000rpm later in the rev range and has increased to 480nm which is what i was aiming for. Max power is slightly shifted later aswell but only by a few hundred rpm. A pair of poncams would help but im going to stick with the stock cams till i have the dosh to get some angry cams in there, most probably when the motor decides to call it a day.
Adjusting the intake cam gear both ways didnt seem to help, it seemed to like it most at 0 but the exhaust got retarded by 2degrees and gained a tiny bit more up top.
Boost comes on at 1.3bar but bleeds down to 1.2bar where it makes max power.
Power vs torque
Power vs boost pressure
Edited by snozzle
all i can say it well done and i very much enjoyed reading this thread, its easily got some of the sexiest+toughest midnight 33R's ive seen thus far. im very jealous having to stick with my gts-t due to my pathetic excuse of an apprentice income. :ermm:
Looking Good Snozzle. Keep your thread going as long as you can, because you most likely will continue with some mods, just like I have done & still going. It becomes a little addictive after a while. :yes:
You've put in some real effort into it.
I am running the Nismo AFM's with the stock airbox & snorkel & don't have any boost/spike problems.
I decided on the standard air box - mostly due to some of the cops here in Melbourne, VIC. :thumbsup:
However I am interested in putting a ARC Box in, some time in the future. I think that should be fine, as Victorian Cops like to see boxes, rather than pods.
I got some carbon fibre parts (Front grill, N1 bonnet lip, N1 Front Bar Slots & Nismo Pillar Garnish) in the mail last week & also got my Tomei S/S Dumps.
Only have to get the Tomei Extreme Manifold Kit, Split Fire Coils & HKS Cam Gears now.
Once I have put everything on & have painted my engine covers, I will post some pics.
Cheers
Cheers
cant wait to see some pics ;)
Thanks man. Yeah i definitely want to run a catch can even if i dont really do any track work but i cant seem to find any good catch tanks that will still retain my windscreen washer bottle.
Ive seen one that looks MINT on another gtr but i cant remember whos it was, it was chrome and had GTR embossed on it which was also polished.
Do you know where i could get a decent catch can setup that will actually work ? Ive kind of left the catch can thing to last as i want to do it once but properly as alot of the setups dont seem to be very effective...
Edited by snozzle
Top secret make one, you can get em from rhdjapan. or just jap make one also
that one youre thinking of though would be a RIPS custom jobby http://www.ripsltd.com/products.html (scroll down to the bottom)
I got Rips in NZ to make mine up..Not cheap but I still earn Japanese yen and got it made up when the Oz & NZ dollars were worth pesos during the GFC.
Yes! thats the exact one im after. Would these cost more than 500 bucks to get made up?
Im going to look into locally fabricating something like this, cheers Mark!
edit: sorry pete, i just realised u posted the link to the same thing already haha
Edited by snozzle
Err these through RIPS are not cheap.
Quality of workmanship is exceptional !!
Like I said I took advantage of exchange rates during the GFC so ended up getting it a good price.
Flick Rob an email for a price.
Hi,
We do them slightly different to that now as we use weld on fittings to take braided or push lock hoses and they have different mounting tags but they are basicly the same (see pictures)
Exactly as it is in the pictures I can do for nzd795 incl shipping, if you want the GTR logo and polish add225.
Regards Rob
I think a JJR one for $249 will do just fine lol
http://www.justjap.com/store/product.php?productid=17416&cat=360&page=1
ive asked justjap for some more photos of the item, if it looks neat ill end up buying this but using higher quality hose/fittings etc
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
