hey all,
my v36 sedan is currently at the compliance workshop so it won't be long now - yay!
in the mean time, i am trying to organise some new rims. it's a my2007 type sp so the stock rims are 18x7.5 (FR) and 18x8.5 (RR). my questions are:
- any ideas what i could go comfortably up to?
- will 20s be too large? are tyres easility available?
- how wide can i go?
- will i need different widths to match? eg 8.5 fronts and 9.5 rears
any help would be appreciated. actual experience would be even better.
thanks for reading.
...sykryd
https://www.sau.com.au/forums/topic/326927-wheels-for-v36-sedan/
20's are fine. Yes they are easily available.
i went for a 20X9.5 +15 front 20X10.5 +18 rear on my coupe, which is *very* aggressive offset.
widths, sizing, and offset is all dependant on how you want the car to sit.
IMO the "stance" (offset & widths) is just as important as actual wheel design choice.
check out http://www.rimtuck.com and searching for a infiniti g37 sedan for some sizing / pics.
Edited by loz-tuned
thanks for the link. thats a great looking website. i couldn't find anything under g37 sedan, but i did find a couple of 19s under g35 sedan.
your set up must look awesome. i can't believe how wide you've gone - 2inches over (my) stock!! i'd love to see some pics if you have them. also, do you have a (4 door) sedan or the coupe?
  • 1 month later...
hey all,
thanks for reading.
...sykryd
Sorry bit of topic dont the 2007 SP models come with 19 standard? mine did but its now causing me problems now with complaince, for some reason they were complanced with 18s.
sedan or coupe? coupes come in stock 19s, sedans come in stock 18s. mine is a sedan.
who is doing your compliance? if they are stock rims, i don't see how it would have any compliance issues. might be harder to get the right tyre placard.
got pics of your rims/car?
Hi all I have 22s on mine 2008 v36 SP. I am looking for anyone who has the Stock 19s as I sold mine to the shop when I got the 22s. I am interested in a swap for the 22s aswell, Just really want to 19s back.
If anyone is interested pls PM me and we can come to some sort of deal
Cheers
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
