I have fitted AP Racing discs and calipers to my stagea as the existing r34GTr ones struggled when I put 2860-5 turbos on .
Used a set for a skyline and everything fitted no problem . My hubs use 14mm bolts so everything was just bolt on except I had to grind off one small bit as it fouled the AP brackets
Before
After
Discs and calipers on
Wheels on (18 inch) and yes I know there are only two wheel nuts on :)
i know everybody is talking about front upgrades but ive got questions about the rear upgrades. i tried doing rear 34 brembos but they dont fit the mounting bolt holes. the spacing of the bolt holes are different. are the r33 brembos the same as r34 or is the spacing the same as stags??
Pretty much all rear calipers have the same hole spacing.
I have 34GTR Gold brembos on the rear of my Stagea
As you can see they do fit but you will need the larger 34GTR discs
Now the bigger caliper bolt holes do line up and they use the same size bolt as stageas the thread pitch is different - you need to use 34 GTR caliper bolts .
If you are trying to use the original stagea bolts they can give the impression of not fitting
Also because the 34GTR rear discs are much bigger you will need to either swop the dust cover for a 34GTR (or 33) one or cut the dust cover lip off. This can easily be done without removing the covers. This is much easier as nothing else needs to be removed ( hand brake assembly etc)
This is certainly true for series one cars If yours is a series 2 I cant say for sure as mine is an S1
Edited by RSVFOURUK
yes mines a ser 2 rs4s. the bolts arent a problem as i have the r34 bolts. i have the gtr discs as well. the problem is definately bolt spacing. when u put in 1 bolt the other hole is out by approx 10mm. i'll take a pic or two on the weekend.
Wheels on (18 inch) and yes I know there are only two wheel nuts on :(
... oh, and aren't the slots in the rotors meant to run the other way? I think you may have left on right, and right on left.
Thanks for your concern and if the grooves were curved you would be right but with straight cut grooves on APs its the other way ( no I dont know why either)
There are lots of different AP disc designs : with these particular discs it is the direction of the vanes that determines the way they go round not the slots.
From the AP website (and off of the AP box :( )
Just brought a set of r33 gtst calipers and are wondering if stock s2 rs4 discs are going to fit or do i need r33 gtst discs
you will need gtst disks and you will either need some pipe with a 12mm inside diameter and 1mm wall thickness
or re-drill and tap the mounting holes to 14mm like the stock brakes are
Please redrill/tap to suit the bigger bolt, using sleeves is very dodgy.
I've got a good set of front R33 GTST S2 rotors for sale - $100 cheap. :P
i dont need a death trap on the road for my kids to drive in
i will definatley be retapping the holes got all the taps at work
will bolt straight on
use a coarse threaded screw and screw it into the restrictor in the bottom of the brake line hole (on the calliper)
then pull it out with something, vice, claw hammer, whatever
then your stock lines should bolt straight in (make sure you keep the 2 brass washers)
Ruby,
I fitted 32 caliper`s up no worries, retaped bolt hole`s to 14mm no bodgy Spacer
post-36964-1278394400_thumb.jpgpost-36964-1278385348_thumb.jpg[attachmen
t=293900:june_10_042.jpg]
I had braided line`s so no worries with Banjo,
I toke them off as i think Stock Setup was better & now with Brake duct`s.
Next is Braided line`s ,
I know many BAG stock setup but i think there as good as 4 POT`S,
Cheer`s Chuckie.
Chuckie,what size of tap did you use?and size of drill bit?your idea looks better than the pipe technique...more info on how to did you do it will be awesome...Thanks
Edited by southern_tango
It should be M14x1.25mm.
Rule of thumb for all tapping drill sizes is; Nominal bolt dia. minus thread pitch.
In this case 14mm minus 1.25mm.Tapping drill size; 12.75mm.
Obviously, use a drill press to ensure you get the holes square, with the caliper firmly clamped. Use a tapping compound or grease to lubricate the drill, not too fast, take your time.
When tapping, use a tapping compound or grease to lubricate the tap, you don't want it to bind or break. Don't be shy, use plenty, it wipes off at the end. Ensure you are using a Taper or Intermediate tap; a bottoming tap will be almost impossible to start. (or just buy a complete tap set; it comes with all three).
Take your time to ensure the tap is straight and square once you start a tap crooked, it can be difficult to straighten. For every full turn on the tap, back off 1/2 a turn to break the chip, when you wind it back, it will go tight, then the chip will break, then release. If you don't do this the thread can start to tear, and feel rough; you want a nice smooth finish. Use a proper tap wrench, not a shifting spanner; it will be much easier to ensure the tap is square.
I hope I haven't oversimplified this, not trying to treat you like an idiot, just wrote for novice use.
Good luck, Dale
Edited by Daleo
  • 3 weeks later...
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
